Placing first ADS order, missing anything?
you guys talking about the same "gun"
Originally Posted by ThumperMX113 The Foam Gun calls for a 4oz for the highest foam setting with 4-6 oz of water in the canister for one wash.
Yes, I put water in the canister. 4-6 oz water, as the instructions say. If you go on AutoGeek.net's website it'll even tell you to use 6-8 oz of water and 2 oz of the DP Foam Gun Shampoo.
I don't know why I said we had the same gun last night. I knew he had the foam cannon. I guess I shouldn't post so late at night. Oh well. I figured the foam gun and foam cannon would be pretty similar in the amount of soap to be added. The two probably flow as much water as each other if not the foam cannon more so why wouldn't the amount of soap be more for it? That's my point.
What's the "better stuff"? I'm sure i'll be placing another order on ADS in the summer, what soap should i pick up? I'll run through that super soap fast.
I think the SuperSoap is just fine to use...I also like Poorboys SuperSuds and Wash but I am liking the SuperSoap and it was FREE. 1 gallon....
Correct. It's MUCH better than Gold Class & Super Soap. I find those two to be about the same. The DP Foam Gun Shampoo is just amazing. It's got a TON of lubrication compared to everything else I've tried. It's $60 though. Needless to say, I'm not going to use it. I feel comfortable not using a soap bucket with the DP soap. However using the Super Soap, I'll use a bucket with soap as well.
