Proper way to use Hyper dressing?
Old Mar 25, 2008 | 10:11 PM
Stragum's Avatar
I got 2 of the 32 oz spray bottles today and was attempting use some, but I could not get the spray nozzle to spray more openly. It only squirted in a stream line.
Anyway I can change this?
Also how much do I dilute it by? Do I just fill the bottle with water to one of the appropriate lines on the side of the bottle?
Sorry guys, I am rookie on hyper dressing. I just want to make I use it correctly before I use it.
Thanks in advance.
Old Mar 25, 2008 | 10:13 PM
dkstone05's Avatar
I just have the gel(no sprayer) and put some in a small container then use a small paint brush to apply it.
Old Mar 25, 2008 | 10:15 PM
cufootn's Avatar
Yes add water first to whatever line of dilution you want then add hyperdressing till the bottle starts to taper. Assuming your using Megs 32oz bottles.
You should be able to twist the very end of the sprayer to adjust the spray pattern.
Old Mar 26, 2008 | 01:33 AM
Grubrunner's Avatar
Meguiars Hyper Dressing offers four different finishes:
High Gloss 1:1
Medium Gloss 2:1
Satin Finish 3:1
Natural Finish 4:1
Old Mar 26, 2008 | 02:00 AM
ELVATO's Avatar
I have the squirter **** "tightened" all the way. Depending on how hard I pull the trigger, it'll spray/mist a wide area, or make a tighter cone. I don't really need a stream of HD shooting out.
Old Mar 26, 2008 | 07:12 AM
Stragum's Avatar
Yeah a stream of HD would not be good, lol. Thanks guys.
Old Mar 26, 2008 | 03:52 PM
f-150sport03's Avatar
HD in a gel? How useless IMO... I use Endurance Gloss gel for the tires, but when I do the u/c, sprayed HD is the best (of which I have about 2 tablespoons left... but it's no accord now...the elders remember it...)
Old Mar 26, 2008 | 03:57 PM
roushstage2's Avatar
HD does not come in a gel form, unless you mean undiluted?
As for how far to fill it up- http://meguiarsonline.com/forums/sho...77&postcount=8
Old Mar 26, 2008 | 03:59 PM
I didnt think it was, but I have been kinda out o the loop for awhile...That was my only guess, but even then... Why??? I wont be found using HD at any stronger than 1:1 (even so, I dont like going that strong...)
Old Mar 26, 2008 | 09:30 PM
FlyerFX4's Avatar
Thanks in advance.
I know what you're talking about with the nozzle shooting out a stream. You have to just barely open the nozzle and you will get a good mist.
