Cleaning engine bay and claying
Old Jan 9, 2008 | 12:17 PM
gators241987's Avatar
Come this spring I plan on getting my engine compartment looking brand spanking new. I also plan on claying my truck. So, what exactly do i need to order from the ads website to do this? Lets pretend I have no supplies.
Old Jan 9, 2008 | 12:21 PM
hivoltagefx4's Avatar
As for your engine, I'd start here:
https://www.f150online.com/forums/sh...d.php?t=315730
Old Jan 9, 2008 | 12:33 PM
Powercat's Avatar
As for claying I used the following:
Meguiars #34 Final Inspection
Meguiars Professional Detailing Clay (blue is not as harsh)
Meguiars M/F towel to buff off
Old Jan 9, 2008 | 01:36 PM
RollingRock's Avatar
you got good responses so far.
I would encourage your to review the detailing sticking at the top of the section.
Secondly, you said Clay the truck....that is only the second step in a many step process. The base for any good detail can be taken from this plan.
Wash
Clay
Polish
Seal
Wax
Old Jan 9, 2008 | 06:41 PM
Wash
Clay
Polish
Seal
Wax
Ive read the sticky and have the 14 page guide, i just want to know which color clay would be best.
Old Jan 9, 2008 | 06:53 PM
Good question.
For Megs it goes in this order.
White-very mild (sold at most places in a kit)
Blue-Med
Red-Heavy Duty
There are also other brands out there. Clay Magic, its Grey and there is another one I buy that is Purple. A cross between Red and Blue.
99% of the time, I use Megs Blue.
Rules of Thumb with Clay:
Cut the bar in half and save one half and use the other. If it touches the ground, do not use it ever again, walk to your nearest trashcan and throw it away. Then grab your other half and don't drop it.
The trick is LOTS OF LUBE. So if you get a Megs kit, get another bottle of QD. For trucks I use a lot of QD.
Not a lot of pressure is needed. I like to Listen to the clay, and you can feel it "release" as each area is covered.
Cheers
Old Jan 9, 2008 | 06:58 PM
Good question.
Blue-Med
Red-Heavy Duty
THanks, it looks like i will be going with the blue, before i clay, there are 4 mentioned applications that i should apply to the paint, M34 Final Inspection, D55 Last Touch Spray Detailer or G13224 NXT Speed Detailer. Which one would be best?
Old Jan 9, 2008 | 07:04 PM
Ok, I think you are a little confused. Or the way your post is worded it has me confused. So lets start over.
All three of those are QD's. Quick Detailing products. All three can be used a lube, you will like the 34 better I assure you, hands down 100% for claying, no need to buy the other ones if you haven't already.
Steps:
Wash
Clay- using Megs Blue Clay and Megs 34
Polish- using what ever polish you want. This is where you remove swirls, haze, marring, scratches etc, paint level and correct etc.
Seal-Optional step here.
LSP-wax.
Does that help out?
Old Jan 9, 2008 | 07:09 PM
yes it helps. Sorry for the confusion, i just know that you have to have the surface wet to clay and i didnt know which product would be the best to use.
Old Jan 9, 2008 | 07:17 PM
Great, you are going to need a ladder.
Old Jan 9, 2008 | 07:19 PM
Ya i know especially in march when i do it after i crank the coilovers and put 37s on. Either that or grow 2 ft.
