Help!!
Old Oct 8, 2007 | 05:27 PM
jb526's Avatar
Help!!
Any ideas on how to get gum off of a vehicle without messing up the paint. I would love to find the person that did this. I tried polishing compound because I was grasping at anything and that didn't touch it. Any suggestions?
Old Oct 8, 2007 | 05:30 PM
hondarider400at's Avatar
i have used peanut butter and gum came off.. just put it on let it sit for a little bit and rub it out..you can also try bug and tar remover
Old Oct 8, 2007 | 05:34 PM
troberts6874's Avatar
goo gone..works great on gum in carpet too
Old Oct 8, 2007 | 05:57 PM
jb526's Avatar
The peanut butter and Goo Gone won't harm paint? Thanks for the suggestions.
Old Oct 8, 2007 | 05:59 PM
f-150sport03's Avatar
Just remember to rewax the area afterwards.
BTW-- make sure you use creamy peanut butter if you go that route!!!
But, I would opt for GooGone or Bug and Tar remover before peanut butter...
There are other options, but these are fine
Old Oct 8, 2007 | 09:32 PM
Rockpick's Avatar
Moderator &
With 'every now and then' use, you're fine. I wouldn't make a habit out of doing it...
As was mentioned, rewax affected areas as all of the products mentioned (including PNB) will remove wax fairly effectively.
-RP-
Old Oct 8, 2007 | 10:57 PM
RUSS04's Avatar
If you can get it DRY ICE Works on gum stuck on a carpet Iam sure it would not harm the paint Just make sure you have a heavey pair of gloves
