Todays project
Would like and appreciate the guidance...should I get a buffer for the waxing? I am not that lazy, but time savings would be nice with a rugrat and wife
I just want to have a balance between time savings and quality. I dont want to do it half a$$. But then again I dont want it to be SHOW quality because of limited time resources. Thanks. I would REALLY appreciate the tips since I now actually have a really nice truck.
"you can pick any two of these, 1. I want it fast, I want it cheap, I want it good" Again any two.
That said. If you want it fast and looking good, my recommendation is that you get a:
Porter Cable 7424 DA Polisher
6" Lake Backing place and a set of Lake pads.
That means, 1 each of the following:
- yellow
- White
- Green
- Orange
- Blue
- Black
Then you will need the following.
- Wash soap, poor boys or Megs NXT, (PB SuperSuds is AWESOME)
- MF wash mitt
- two buckets (grit guards are optional)
- 1 clay Bar and lube
- Polish and wax
- MF towels (10 min)
- QD, pick one
After that, you should be able to detial your truck in around 5-8 hours after the FIRST time which should take you at least a full day or more.
Ok, that looks like a lot, and it is...but if you want to go fast that is my recomendation, anything else you will be doing it by hand and that is HARD work.
It can be done, just ask Zaairman or RockPick, Gip-er, F150Sport......and others
I am lazy and I like tools so I do it my way....and that doesn't always work for everyone.
that should open up some questions and VERY, VERY sorry to hijack this thread.
whats the best way to get scratches out and touch up paint chips. for some reason i find new scratches on my truck everyday.
Rolling Rock...wheres the thread about getting asked to leave property while dove hunting. Would LOVE to read that one.
Cheers
Originally Posted by CANES676400
thanks ill look into it
Originally Posted by Shinesintx
For small clearcoat scratches, 3m makes a Rubbing Compound (Fine). You have to use lots of elbow grease, but you wont take off alot of the clearcoat. Follow the directions, and use a soft cloth.
For chips, goto the Ford House, give the VIN, or get the color off your door. Cant remember which. (they will know) Get the small paint applicator, dont get the pin. Use several light coats to fill the chip. You may have to wet sand the outer rings that it will leave. Take your time and apply several aplications. You are just trying to build up the hole where the chip has been vacated. It may not be as good as a new paint job, or the original paint, but it will look way better than the chip.
Remember, the slower you go, and the more **** you work, are in direct proportion to the end result.
Um hold off on that and use as somewhat a last resort.
Try some Megs ScratchX first and see if that takes care of your problem areas. SX also has some concealing properties with it that is helpful.
Do a search on ScrachX here and you will find a ton of info. Not all compounds are the same. Each has its own property and make up when it comes to CUT factor.
Its ALWAYS best to use the least aggressive method first, then get more aggressive as needed. This is where having a selection of products is key.
Do you have some photos of the problem areas we could look at before getting to crazy on the paint?
RR
Originally Posted by RollingRock
My Belgian Cabinet maker neighbor tells his customers this
That is a whole other topic and I would encourage you to use the "search" feature.
This is also a whole other topic but I didn't start a thread about it. Lets just say I shot 6 birds and got them before the Land Owner said "get the hell out of here"
Cheers
- yellow
- White
- Green
- Orange
- Blue
- Black
- MF wash mitt
- Polish and wax
- QD, pick one
Cheers
Is there a one stop shop? Where or who carries this stuff locally?
Then if you want next day delivery on Lake Pads and Poorboy products you can check this guy out
I just ordered another order tonight to restock some products.
http://www.specialtymotoring.com/
Scott is a good guy down in Houston. He carries the full line of PB products as well as Optimum and ClearKoat.
Many here will tell you in the C&D section I am some what of a PB's bigot.
I love Meg products but my true love is with PB and Optiumum.
I buy all my Megs products exclusively from WashSolutions in Dallas...just off 35 near Parker College. I was just there on Friday to give them some $$.
RR
RR
rollingrock wheres the doc. in ur email
Patience grasshopper. Ryan is a busy young man.
If you need something right now, send me your questions via email and I will take a shot at them.
I think we have hijacked this thread enough.
Back to the OP on this.
JP'
From my experience, 3M FINE rubbing compound takes off very little clearcoat. Thats why I said it would take alot of ELBOW GREASE. The product you suggested may be an equivalent as to what I suggested. To get rid of a scratch, ya dont fill it with wax, you have to take the clearcoat down to the lowest level of the scratch. Maybe I am just crazy, but it worked for me.
Most cut products need heat and pressure to work and breakdown effectively.
I still don't' recommend using a true compund until you try the least aggressive methods first. Here's why. Lets say you have a 50% prepped finish and you go to town with elbow grease using a compund. What are you left with? Dirty paint with a shiny spot that will require more elbow grease to level the surrounding clear to make it blend.
Not disagreeing with you but rather trying to help based on errors I have made in the past.
If you have marring or micro marring AKA spider webbing mild cuts like Megs #80 or #9 will do the trick. With anything deeper you are going to need ScratchX first, then a product with a cut of 5 or more like Megs 82, or PB SSR 2.5 or SSR3.
Its hard to really judge the prop products without seeing the marring.
But I would say if a Cut pad and SSR3 doesn't get it, then I would go to a true compund or wet sand. That is a whole other topic.
Just hit 100!
This ain't the GD area...make these posts count. People come here for REAL info.
All kidding aside, the C&D section is taken very seriously. This is hard core stuff. You can really jack up your finish on your beloved investment, so the elders take time and patience to make sure we answer questions with as much detail as possible.
That is why I told you not to use that "leather conditioner" a buddy gave you on your new KR.
Originally Posted by 07stxscab
Again, nice work.
JP
D.A.M.N. Noob
