Removing Baked on Brake Dust - HOW??
Like I said before this is to be used on coated wheels only!
Stock chrome steel, stock clear coated AL wheels, painted wheels etc..
Raw or bare AL\SS will cloud white!!!!!
It is actually a compination of Hydrfloric\Muratic acid, some folks use it as a concrete driveway cleaner
Also a great shower door soap scum remover ( PLENTY OF VENTALATION!!!)
I definatley dilute my solution 1\3 to a gallon of water.
Even then it is a very short soak on the wheel.
The way I use it as I stated is with a syphone, made from a air blower, and small hose for the pick up.I'll post some pics within the next couple days.
Wet vehicle, spray wheels and tires, hit the bumpers, grab pressure washer and rinse her down, just that fast.
After you get all the gunk off it really is as quick as that.
Again, I want to say that this is HARSH stuff breathing it in WILL burn, eyes as well. and yes TURTLE313 That is the stuff, but dilute it even more if you plan on using it at the house. AND WEAR YOUR RUBBERS!!!!!
.Also a great shower door soap scum remover ( PLENTY OF VENTALATION!!!)
