Water spots - pics inside
I discovered these a few weeks ago and attempted to remove them with Meg's clay bar, #9, #7, and #26 applied with PC and 8006. I bought a 7006 pad and some Meg's #2 fine cut cleaner but wanted to get the expert's opionions first. Any suggestions?
https://www.f150online.com/galleries....cfm?num=14253
The truck is filthy at the moment because it has rained every day for the past 2 weeks. I only attempted to remove the spots on the hood but ran out of time/patience before I got to the fenders. The spots are only on the horizontal surfaces of the truck.
Originally Posted by troberts6874
i would try a more aggresive compound, i dont use megs but i think its 80,81,or 85. or just use a rotatry polisher.
Do a search on Water Spots, a great thread was started about this the other day.
Here was the link to the helpful tip
http://archive.meguiarsonline.com/fo...?threadid=4891
I would start with #80. It might take multiple passes with the PC, just take your time and work the product correctly.
you could start with a 7006 pad, then make another pass with an 8006 .. you might get some slight micromarring from the 7006.
