Any suggestions for storing my truck
I am going out of the country for about 4 months and will not be driving my truck during that time. I have found some websites with storage tips, but they seem a little extreme for the amount of time I need to store my truck. I was just seeing if yall had any suggestions!
Four months is not long enough to worry about. I'd fill her up (you might want to add some Sta-Bil just to be on the safe side), check the air pressure on the tires, and let it sit.
If you're storing it outside, I'd throw a good coat of wax on it and maybe put a cover on it or at least one of those sun shades to keep down the sun-related wear-and-tear on the interior.
Years ago, I use to travel out of the country for months at a time and I did that for over 10 years. I had over 2 dozen vehicles, some of which I kept in long term storage, but storage was always an issue. Definitely use a fuel stabilizer as previously mentioned. If you don't have a battery maintenance system, then disconnect your battery if you don't mind the effects from it. I kept/keep many of my vehicles plugged into a battery maintenance float chargers to prevent discharge and Lead Plate Sulphation, which is what will kill your battery. You can buy a decent charger / maintainer for under $50 off the internet or from local stores such as WalMart. One of the nicer inexpensive WalMart charger / maintainers to check out is the Schumacher SC-1200A fully automatic speed charger. Sear's also sells a similar charger / maintainer. I probably have a half dozen of the VDC systems that I use in addition to a custom float charging station I use for the vehicles that I keep in long term storage, but I also have a couple of the Schumacher SC-1200A's that I've been using for years with good results on certain vehicles.
Four months won't be a problem if you're using a fuel stabilizer and maintaining the battery, but if you're storing vehicles for years at a time, then you'll run into all kinds of issues that need attention (battery, fluids, tires, seals, etc).
As far as changing the oil, I would do so before storing. That way its stored with fresh oil instead of the dirty oil thats been in there for how long. I put my Mustang away during our fantastic northeastern winters and change it right befor eI store it and give 'er a good coat of wax and plug a batter tender into it. When I start it in the spring, I pull the coil wire to crnak it over until the oil pressure is built up, re-install the wire and she fires right up.
i am a Marine and i go out of country all the time, i change the oil fill the fuel tank add some fuel stabilizer, and diconect the batt. when i get back i change the tranny fluid and diff fluid, but i leave for longer than 6 months
