Water Spots on Windshield
Old Jun 18, 2007 | 12:33 PM
CruisinKen's Avatar
How do you get the water spots off the windshield - the ones in the area where the wipers don't clear. I have tried Stoners and Windex but no luck. T
Kenny
Old Jun 18, 2007 | 01:43 PM
06darkstone's Avatar
have you tried WD-40? Lime away may do the trick also
after you get them off put on some rain-X and the water will roll right off
Old Jun 19, 2007 | 12:25 PM
CruisinKen's Avatar
06darkstone
Thanks for the ideas - I will start with the WD-40 (on hand). If that doesn't do the trick then Lime Away. I guess straight vinegar would do the trick also - any thoughts on that?
Kenny
Old Jun 19, 2007 | 01:48 PM
Bartak1's Avatar
Barkeepers Stovetop cCeaner. I used it quite a bit and it works wonders
Old Jun 19, 2007 | 02:49 PM
Rockpick's Avatar
Moderator &
Hi Ken... there are several items that may work. I'd dodge the WD simply because of the problems involved with removing an oily product from a nearly non-porus substrate (the glass).
I would, however, try the vinegar.
If that doesn't work, snag some Easy Off 'BAM' bathroom cleaner. Apply it directly to a TOWEL (not directly to the windshield), and use EXTREME (did I mention EXTREME?) care to not get it on ANYTHING other than the glass.
This *will* remove the spots (similar to the Lime Away recomendation from an earlier post).
Follow with the Stoner's as it will not leave a streak free shine.
Enjoy.
-RP-
Old Jun 22, 2007 | 10:29 AM
izzyzlat's Avatar
I've tried everything to get water spots off for a while, nothing has worked for me till now...
I bought a can of "Rubbing Compound" from Pep Boys for $1.99...got rid of ALL waterspots.
Old Jun 23, 2007 | 10:26 PM
RedOregon's Avatar
Originally Posted by CruisinKen
06darkstone
Kenny
Save your money and break out the vinegar. Doesn't have to be straight, though... I used about an inch in the bottom of a water glass, filled it the rest of the way with water, then swiped a sponge from the wife's sink and took it to the windshield.
Was coated with hard water crap so bad you could hardly see thru it when the sun hit it wrong. Coupla minutes with that diluted vinegar and it was *all* gone
Old Jun 24, 2007 | 06:57 PM
STXDriver's Avatar
Never heard of WD-40 on a windshield. Learned something new today.
Old Jun 24, 2007 | 08:51 PM
Silverfish's Avatar
Smile
RainX works for me
