Questions on using paste wax with a PC
Old May 21, 2007 | 09:46 AM
scorpio333's Avatar
Should pastes not be used on a PC?
If it's ok to use them, then what methods work best for applying? Any tricks?
I've tried scooping straight onto the pad and also applying a couple one foot long passes about 8 inches apart then using the pc to even them out.
Old May 21, 2007 | 09:54 AM
Rockpick's Avatar
Moderator &
Absolutely -- you can use pastes on a PC.
The trick is getting it from the tin to the pad... to accomplish this, I typically use an applicator and work it from the tin and on to the pad as evenly as I can.
Once on the paint, I'll work it around in a small area to try to further distribute the wax across the pad. From there, I'll work on spreading everything that I've applied to that one small point across a larger area while keeping in mind that thinner is better.
-RP-
Old May 21, 2007 | 12:41 PM
LRG's Avatar
LRG
I saw a post on MOL about a guy using the back of a spoon to pick up some wax and transfer it to the pad and smear it around. I haven't tried it myself but it looked like it worked pretty well from the pics he took demonstrating it. Might be worth a try, seemed quick, easy, and clean.
Old May 21, 2007 | 02:27 PM
scorpio333's Avatar
Thanks guys. I've got to add a 2nd NXT today so I may try an applicator, clean plastic putty knife or plastic utensil.
Old May 21, 2007 | 06:12 PM
Drunkonjack's Avatar
what is a PC
Old May 21, 2007 | 07:16 PM
ridge's Avatar
Originally Posted by Drunkonjack
what is a PC
its a DA polisher look up portal cable 7424
Old May 21, 2007 | 10:34 PM
Rockpick's Avatar
Moderator &
what is a PC
It's a dual-action polisher. PC stands for Porter Cable -- the manufacturer.
You'll hear this machine referred to as either the DA or PC...
LINK
Old May 23, 2007 | 11:05 AM
rustyzipper's Avatar
I refer to it as being the, Holy Grail.
