Window Care.
Old Apr 14, 2007 | 11:17 PM
minimonster17's Avatar
Window Care.
Hi, all. What is the best approach to remove scratches out of windows? Is it possible? All of my glass seems to have some scratches on it, with the exception of the windshield, but my driver and passenger windows are the worst. It has, what looks like long scratches going straight down the window on the outside, perhaps from some kind of scraper used in the past? What, if anything, can I do about this?
Old Apr 15, 2007 | 01:36 AM
rustyzipper's Avatar
Picked this up off of Auto Geek.
Best way to get glass to look new is a cerium oxide polish for glass..it will give glass the new car look....use with a PC and a 4inch pad...glass turns into a diamond..removes scratches, smooths out pits, so less noticeable... use a 4" green or orange pad to polish glass...google cerium glass polish ...look at them all on the first and second page...prices vary...mine was $29.00.
Old Apr 15, 2007 | 09:13 PM
Does the cerium oxide truly get rid of the imperfections, though, or does it merely serve as a concealer, and need to be applied again?
Old Apr 16, 2007 | 02:42 AM
>>>Does the cerium oxide truly get rid of the imperfections, though, or does it merely serve as a concealer, and need to be applied again?<<<
I can't say. I've never used it myself. Just putting you on to a lead. It does state it removes scratches as you would be polishing with a PC-pad. Again, the info came from the Auto Geek web-site forums.
Old Apr 19, 2007 | 09:40 PM
Rockpick, would you happen to know if the cerium oxide is a permanent solution, or do you have any other suggestions?
Old Apr 19, 2007 | 10:35 PM
Rockpick's Avatar
Moderator &
I don't. I appologize.
You may do some searching online (try a google) for Diamondite as well.
Old Apr 20, 2007 | 10:23 AM
ridge's Avatar
is this scratches or just really bad scuffs, several detail shops told me that on older cars you could use toothpaste to clean a window and it would do so good that it looked like brand new glass, however what they also said is do-not use the toothpaste trick on tempered glass because its mainly plastic and the toothpaste will just screw it up, but i do know mequires has something for glass that guarentees to get out small scratches and scuffs, you might want to look it up
