Micro-fiber towel fact
Today as I was wiping the wax from my truck with my micro-fiber towels,I noticed something very interesting; new towels work better then washed towels.Ok,before you laugh heres the lowdown.I have about 8 towels that have only been washed once,after only one use.I opened a new 3 pack today just to see how the once used worked against the new ones.The old ones left a few streaks while the new ones were flawless.Am I the only one who has noticed this? Could it be the way I washed the old ones? I washed them alone with Tide,dried with no fabric sheets.
I notice that too.Sometimes I'll use a previously washed towel to remove wax and then I'll use a new towel to give it a final wipe down.
But I usually use new towels on my truck and used ones on my cars.I'm pretty compulsive so I keep 4 or 5 pkgs of new microfiber towels on hand.
Originally Posted by BlueOvalFitter
Is that a GN or a GNX? What year if a GN? Miles?
I also have a GNX clone(can you blame me real GNXs are going for $75k -$100k)
If I could afford a real one I'd have to be crazy to drive it.
Originally Posted by ws6_guyscrew
yeah I noticed that also, i put it all in the4 gentle cycle anymore helps keep it long lasting.
Whats under the hood of the GN? 5.0L 305 or 5.7L 350?
There is a doctor here at Tampa General hospital with a GNX!
I've seen it at a few local car shows.It has like 8-9k miles on it.If i'm not mistaken I think its in the 40s-50s number range.Didn't they only make 502 GNXs?
add some white vinegar to tthe wash cycle, double rinse them , dry them on gentle .. that should help ..
as for the WS6 question ..
assumming you are talking about 4th gens ...
WS6 performance package consists of ..
- Ram Air hood and air intake (like that of the Firehawk)
The 1998s and up WS6s have a completely new hood with 2 functional intakes right above the standard non functional nostrils
- Freer flowing exhaust system
- Higher rate front springs (360 lbs/in)
- Variable rate rear springs (130-180 lbs/in)
- Stiffer front and rear shocks
- Harder bushings
- Larger diameter front anti-sway bar (32mm)
- Increased cooling
- 17 inch wheels with 275/40ZR/17 tires
- Harder bushings
- Increased cooling
They come from the factory with a turbo V6.
Originally Posted by Gipraw
add some white vinegar to tthe wash cycle, double rinse them , dry them on gentle .. that should help.
about how much Vinegar? (assuming the load is full)
You dry them in the machine??? Would it be better for e to dry them, 'cause right now I hang them up to dry...
As for the original post---yeah. I see this, too. For me, though, it's only after I've used the towels about 3 times. Even after I wipe down with another one (still used), I still end up with streaks. That's when the Gold Class towel comes out--it's reserved for removing streaks.
Windows or paint?
Are you talking about windows or paint? I wash my MF towels for windows serarate from all the others.
As far as washing towels with wax in them I have found that a micro-fiber detergent or Dawn dish soap works better that liquid Tide/all others. I washed my towels the last couple times it hot water/warm rinse with half cup of distilled white vinegar in the rinse cycle. Dry on low heat. They came out better than when they were new. Using the dryer seems to fluff them up a little better than hanging them out.
Hope this helps, Tic
1 - no chance of mildew
2 - no chance of contamination
3- helps remove any lint on them
4- speed .. I use so many, that if I had to wait days for them to air dry in the houston humidity, I would have to invest another $500 in MF towels, or I would never get anything done ..
drying them on gentle shoudn't hurt them at all ..
as for how much vinegar, I use 1 teaspoon per towel .. 6 teaspoons = 1ounce. don't remember where I got that from, but it seems to work fine for me ..
also .. as mntioned, I also wash and dry my window towels sepereate from the ones that I use for wax/QD removal and claying ..
