water spots
Old Oct 23, 2006 | 01:38 PM
budda 70's Avatar
water spots
I Have Severe Water Spots On My Paint . I Have Tried Waxing But No Luck. What Else Can I Try To Get The Water Spots Out?
Old Oct 23, 2006 | 01:41 PM
red06f150's Avatar
You can try a polish on a DA. Try a polish with some cut, maybe like a megs #9, or there speed glaze. It'll get rid of swirls marks as well.
Old Oct 23, 2006 | 02:30 PM
Rockpick's Avatar
Moderator &
Meg's #9 has little to no cut... really not going to give you much help.
There are two types of water spots... a Class I and a Class II (or at least this is kind of how I was taught to deal with them).
A C.I. will be 'ABOVE' the paint whereas the C.II. will be etched into the paint. Both can be removed but, obviously, the second type is much more difficult...
Can you tell if the spots are ABOVE or IN the paint? Let us know...
RP
Old Oct 23, 2006 | 04:28 PM
budda 70's Avatar
RP
I BELIEVE THEY ARE ABOVE THE PAINT.
Old Oct 23, 2006 | 04:42 PM
Rockpick's Avatar
Moderator &
Double check it... if it is, clay should be a very good option for removal. If there is a slight residual or if the spot has etched very slightly, you may try a product like Meguiar's Scratch-X to remove that.
You have the better of the two types... it's an easier fix.
RP
Old Oct 23, 2006 | 05:01 PM
budda 70's Avatar
RP
thanks i will try the clay
Old Oct 26, 2006 | 12:05 AM
KiCk aSs FX4's Avatar
there is this realy good water spot removal stuff that I have that works really well but I forgot the name. I alsodid it on the glass. not sure if it would be good for the paint.
Old Oct 26, 2006 | 09:30 AM
05supercrew's Avatar
Can you please find out the name, my glass has some really bad spots that wont come out.
Old Oct 26, 2006 | 11:56 PM
Rockpick's Avatar
Moderator &
https://www.f150online.com/forums/sh...47&postcount=4
Old Oct 27, 2006 | 09:13 AM
Thanks, Ive tried all but the steel wool with no success. May need to get the polish and rotory. By the way thank you for all your past help. Just bought all detailing waxs etc. into my house to get them out of the cold garage. I remembered you posted that last year. Good reminder.
Old Oct 27, 2006 | 10:53 AM
Rockpick's Avatar
Moderator &
Thanks for that reminder... I'll post that one again now..
Old Oct 28, 2006 | 02:47 PM
Darkstoner's Avatar
I have had real good luck using distilled vinegar with water spots that are the on the surface.
Old Oct 28, 2006 | 06:03 PM
I tried that first with no success.
Old Oct 29, 2006 | 08:47 PM
Rockpick's Avatar
Moderator &
Some really harsh acid rain (or other industrial fallout) can etch glass.
Can you scrape them with your fingernail?
Old Oct 30, 2006 | 10:04 AM
I cant scrape it with my finger nails but I tried it with a razor blade and got a lot of white resedue. My other cars and trucks dont look half as bad as my f150.
