Best way to bring back my polished stainless steel shine?
Old Oct 14, 2006 | 08:08 PM
at7427's Avatar
What is the best method for getting my polished stainless steel exhaust tip its shine? Right now it has a dull yellowish haze to it and havent had any luck polishing.
Old Oct 14, 2006 | 10:45 PM
Rockpick's Avatar
Moderator &
www.heavymetalpolish.com (medium)
Old Oct 15, 2006 | 11:38 AM
Mark05KR's Avatar
I use Adam's Metal Polish. It works on my stainless steel tips and the polished aluminum grilles.
http://www.adamspolishes.com/site/de...4AA4&killnav=1
Old Oct 16, 2006 | 12:24 AM
1fast4.6's Avatar
get some 000 or 0000 steel wool... works great.. then after that.. hit em with some polishing stuff.. you can polish about anything aluminum
Old Oct 17, 2006 | 08:23 PM
bullitcolor150's Avatar
I use 2000 grit wet or dry sand paper and wet sand it, then when all the contaminents are gone and any scratches or dings are removed i go back over it with some rubbong compound to brighten it back up.
Old Oct 18, 2006 | 12:13 PM
crzy88lx's Avatar
there is no better product than this stuff.
http://wizardsproducts.com/Merchant2...Category_Code=
The more you use it, the better it gets too. it looks like cotton candy, and you just rip a piece off and start rubbing it on the metal. it will turn black after a little bit, an dthen you just wipe/hand buff clean. repeat maybe a couple of times and you will not be disapointed.
Old Oct 18, 2006 | 12:33 PM
Gipraw's Avatar
the two I like best are Heavy Metal like RP posted, and Metal Armor.. I like the metal armor because it has a sealant as a final step that really brings out the shine, and does a great job of protecting .. the heavy metal does a great job on really dirty pieces..
Old Oct 18, 2006 | 12:37 PM
Padron's Avatar
I like Meguiars NXT All Metal Polysh, It's cheap and works great, can be found locally too.
Top it with Finish Kare's 1000P High Temp wax:
http://www.fk1usa.com/products-consumer.htm
