Anyone else have trouble with the unlocking?
Old Dec 15, 2005 | 09:26 PM
S_Gibson's Avatar
I have a '98 F150. Nothing fancy and not power locks. That dog on thing gives me grief sometimes when I try to unlock it. I have to jiggle the keys quite a bit to get them to unlock. It happens on both dores with both keys I have. Is this by any chance a common problem? Anyone else had this trouble, I've been dealing with it for over 3 years now and it seems to be getting worse.
Thanks!
Old Dec 15, 2005 | 09:50 PM
litnfast's Avatar
Try spraying a little graphite into the locks. They probably just need a little lubrication.
Old Dec 16, 2005 | 02:51 PM
tl3demon's Avatar
Mine only does it because of attempted break in that happen a couple years ago!!!! :santa:
Old Dec 16, 2005 | 03:03 PM
Bent6's Avatar
25 Year Member
By far the best thing I've found to use in the locks is PB Blaster. It is a rust penetrant spray. I have tried graphite, WD-40, lock-ease... The Blaster frees up the lock in seconds, and it is good for 6 months to a year after that. I've been using it for 4-5 years with no ill effects. Hope this helps. http://www.pbblaster.com/store/morei...m?Product_ID=1
Old Dec 17, 2005 | 09:37 AM
Whapt's Avatar
my passenger side is that way... The drivers side works fine
Old Dec 17, 2005 | 05:48 PM
S_Gibson's Avatar
Yeah graphite didn't do a thing for mine. It is a major pain to have to sit and jiggle the key every time I want to get in the truck. It really ticks me off if it is raing outside.
I guess I'll give this PB Blaster a try, thanks!
Old Dec 17, 2005 | 05:58 PM
expy03's Avatar
I've had the same problem on several of my Fords after a few years. Easier to just replace the lock and stop the pain!
It's not hard to do. I've done it to several of my trucks. One I just did it to re-key because I had bought it used.
good luck.
Old Dec 17, 2005 | 08:14 PM
Dragan's Avatar
good luck.
I have a 98 Explorer Sport that has had the same issues (still has) on both doors even after using graphite and having the dealer repair them. Seems they do a quick fix (lube) but never take care of what's really going on. I agree with Expy and will go ahead and replace the locks
Old Dec 18, 2005 | 10:07 AM
Bent6's Avatar
25 Year Member
It really does work the best and lasts a long time. Please post your results after you try it, since few here seem to believe me. I hate to see people spending money and time on door locks when 10 seconds with a $5 can of lubricant will fix the locks for a long time. Let us know!
Old Dec 18, 2005 | 12:47 PM
expy03's Avatar
I used the graphite on my locks when stationed in MD. Much better in the winter.
Old Jan 10, 2006 | 04:42 PM
AAlmeter's Avatar
PB Blaster
Love the stuff.
Now I just need to figure out why my power locks are working intermittently.
Old Jan 10, 2006 | 10:25 PM
98Navi's Avatar
Graphite has always worked for me, but I don't know if I see the point of PB Blaster though. I know what PB is, but the lock isn't rusted and jammed, well the penetraing oil, I see your point. A new lock cylinder is like $12\
And my power locks are possessed as well. From what I have read, the GEM module is dying. chit
Old Jan 10, 2006 | 11:49 PM
Peacemaker's Avatar
Mine's done that a few times. As was mentioned, a shot or two of PB Blaster in the keyholes will do wonders.
