Bird***** on my 04!!!
Old Jul 25, 2005 | 08:43 PM
NC FX4 Scab's Avatar
Unhappy Bird***** on my 04!!!
Guys, I hope you can help me. Yesterday I found some birdcrap on my gloss black B pillar. I washed the truck as soon as I found it, but it was after a 95+ degree day, and now I have dull back swirls marks that outline the ***** stain. I tried using a Bug and Tar remover that said it could remove birdcrap, but the dull marks are still there. Any suggestions on how to be rid of this mark on my truck?
Old Jul 25, 2005 | 08:50 PM
FordTruckMan82's Avatar
You can use a polishing compound and that will get rid of it. I removed a really bad bird $*#@ stain from someones car where the stain had been their for years with 3M Polishing Compound. Just be very careful not to ruin your paint, and make sure you put a coat of wax ontop of that B Pillar when your done using the compound.
- Chris
Old Jul 25, 2005 | 09:19 PM
Rockpick's Avatar
Moderator &
I'm almost certain that the b-pillars are single stage paint...
When you tried the B&T remover, did your towel show signs of 'black' as if you were removing paint?
FYI, you're probably not going to be able to totally remove it but, we can probably lessen the appearance.
RP
Old Jul 26, 2005 | 07:32 AM
RP
I didn't notice any black residue coming off on the towel, but then again I wasn't real aggressive with it, either. I'm going to try the rubbing compound idea, and see what I can do with it...freakin birds, getting even with me after my run-in with a mocking bird last week!!
Old Jul 26, 2005 | 08:18 AM
Rockpick's Avatar
Moderator &
Good luck... like I mentioned, it might be a tough one to totally remove.
Also, with the compound, don't 'focus-in' on a spot and rub and rub. If it is clearcoated (mine are flat black so I can't really test on my 05'), the compound will spin through the clear on that panel in short order (ie: definitely ruinining it) so, with that in mind, be VERY careful with that area. Think of a 'rubbing compound' as 4000 grit sandpaper.
RP
Old Jul 26, 2005 | 11:38 AM
I don't think you can stress enough how careful you have to be with the compounds. They can be your best friend and your worst enemy if your not careful.
Have you tried Meguiars Body Scrub I know some automotive places sell it.
- Chris
Old Jul 26, 2005 | 06:08 PM
04 RED LARIAT's Avatar
Man........that thread title says it all.
Old Jul 26, 2005 | 10:12 PM
Red...
Don't go laughing too hard...my truck is a FX4 version of yours! Keep laughing and you'll have every bird nearby circling your truck like a buzzard in the desert smelling rotten meat!
Wait a minute...I wouldn't wish it on my worst enemy...keep your truck under cover....
Rockpick's Avatar
Moderator &
Yeah... I keep having this reoccuring nightmare...
Old Jul 26, 2005 | 10:30 PM
And somewhere Alfred Hitch**** is laughing his British a$$ off right now....
Old Jul 27, 2005 | 10:17 AM
Rockpick's Avatar
Moderator &
HAHA! And Gottlieb Daimler and Karl Benz are rolling over in their graves...
Old Jul 27, 2005 | 10:24 AM
3valve's Avatar
Remover
I know its been talked about before here, but I bet this would work if caught soon enough.
http://www.poorboysworld.com/bird-sht-remover.htm
Old Jul 27, 2005 | 10:33 AM
Rockpick's Avatar
Moderator &
If caught soon enough, sure. Just about any product would honestly.
If I'm not mistaken, PB's BS Remover is a bit more on the alkaline side of the spectrum in an effort to balance the pH from the bird poo (acid). Etching, on the flip side, is a different story unfortunately...
Old Jul 27, 2005 | 04:08 PM
Oof I would just burn it.
NC FX4 Scab....I wasn't laughin at ya man.....I just went out and pulled my truck around infront of the garage and I have bird crap on my door, window, and step board.......Thanks alot.
Old Jul 27, 2005 | 04:56 PM
zapster's Avatar
thats what the racecar (sig) looked like one morning after we parked the car(old days open trailer) under some trees when we went to gators in gainsville..
yuk
took us 3 hrs to get it clean
no wonder nobody was parked at the end of the lot
live and learn
...zap!
