Stainless steel tip help
Old Jul 10, 2005 | 10:11 PM
COFX4's Avatar
My stainless steel tips need a polishing, they are getting a little discolored toward the inside of the tip. What do ya'll use to polish stainless steel? I'm dissapointed these magnaflow tips are doing this.....
Old Jul 10, 2005 | 10:22 PM
Flareside150's Avatar
Double or triple steel wool and some rubbing compound, then hit it with some polish of your choice.
Old Jul 10, 2005 | 10:50 PM
Rockpick's Avatar
Moderator &
Zero problems with discoloration on my Magnaflow tip but... I'll certainly keep an eye open for this...
As for my Stainless parts, I use Heavy Metal Polish. Boss429 mentioned them once to me and I've been hooked ever since using their product...
RP
Old Jul 10, 2005 | 11:22 PM
WVtrucker's Avatar
Mothers mag and aluminum polish has always done well for me.
Old Jul 11, 2005 | 12:13 AM
Peacemaker's Avatar
I've got Magnaflow 18" x 3" tips on my truck. And they have a little color fade due to carbon deposits at the bottom edge of the tips. I just use a toothbrush and some simple green or something similar. Steel wool will leave scratches on your tips. Then polish the tip(s) with a good metal polish.
Old Jul 11, 2005 | 07:02 AM
roboots21's Avatar
As for cleaning the tips, I use Armor All Wheel Cleaner. I use it on my rims when the brake dust is really bad, then on the tips also.
As RP stated, the Heavy Metal Polish is the best polish I have used to date. I would suggest getting the medium abrasive and ultra fine abrasive polish. Follow medium with ultra fine, and they will look just as good as new. My tips have been through a new england winter, and with a little polish, the shine came right back. Highly recommended by myself and RP, and Boss_429 it seems. You can't go wrong!
Old Jul 11, 2005 | 08:03 PM
COFX4's Avatar
Thanks guys..........
Old Jul 13, 2005 | 10:13 PM
kaliscrew2k2's Avatar
I agree, and almost every place sells it.
and yes, that is the stock system.
