Bought the Langka kit...
Old Apr 6, 2005 | 08:15 PM
litnfast's Avatar
O.K. I purchased the Langka kit in the hope that I could fix some chips in the paint on my "01"...
A few months ago on a return trip from Disney World we encountered a road resurfacing crew on the FTP.
Tar covered pebbles bounced up and hit several areas on the truck taking the paint off in some pretty nasty examples of paint chipped surface...
Heres a PIC...
I put a "Blob" of touch-up on the area after using the paint prep solution...
In a couple of days I will go back and use the "Blob Remover" and I will post pictures of the results...
I hope this is not a repeat of a previous post/ I am unaware of any previous before and after photos.
Back with ya in a couple days...
Wish me luck...
Bill-aka-litnfast
Old Apr 6, 2005 | 08:18 PM
litnfast's Avatar
OOPS...
Obviously that's a picture of the kit...
Heres a picture of the chip...
Old Apr 6, 2005 | 08:21 PM
litnfast's Avatar
Old Apr 6, 2005 | 08:33 PM
litnfast's Avatar
With the paint "blob"
Old Apr 6, 2005 | 08:58 PM
So is this kit supposed to "color match" the vehicle, or is it merely designed to "level out" deep nicks in the paint, with a final touch-up applied using one of the factory-colored tubes of paint?
Old Apr 6, 2005 | 09:08 PM
litnfast's Avatar
The kit is only designed to level out the chip.
I used the Ford paint...E-4 in my case...
Old Apr 6, 2005 | 10:01 PM
Rockpick's Avatar
Moderator &
So, can we expect leveled blobs tomorrow?
Old Apr 7, 2005 | 05:20 AM
AhsGrad1973's Avatar
I would wait at least 3 days before using the blob remover, otherwise the paint will be too soft, and will pull out.
Old Apr 7, 2005 | 07:46 AM
litnfast's Avatar
I'm going to try the "Blob" remover Friday morning.
I have never been good at this sort of thing.
If it works for me it will work for anyone:o
Old Apr 7, 2005 | 09:24 AM
RUSSELL336's Avatar
I think you will be pleased with the results. I have used this kit on my truck and you cannot tell where the repair was done.
I have since polished and wax and the repair is still perfect.
Gary
Old Apr 7, 2005 | 12:31 PM
Rockpick's Avatar
Moderator &
Good deal man. Take your time and do it right!
I look forward to hearing/seeing your results.
I know I'm sick and tired of sanding out all of my 'blobs'. It takes forever! Although, I have gotten pretty good at it...
RP
Old Apr 14, 2005 | 05:25 PM
tsc's Avatar
tsc
Survey says?
Any results yet?
Old Apr 15, 2005 | 08:13 AM
litnfast's Avatar
RP
All I can say is "Keep Sanding"...
I followed the directions, waited three days, used a t-shirt wrapped around my index finger and rubbed and rubbed. The paint came out of the center of the blob
I tried again...This time using mineral spirits to clean the site. I applied two new blobs. Then I waited 24hrs and went at it again.
This time using a bed sheet material and the plastic card supplied with the kit. Same results! I managed to pull the center out again.
I cleaned the site again and applied two new blobs. I will try again this Sunday after giving it 7 days to harden...
Maybe the third time will be the "charm"
Old Apr 15, 2005 | 08:41 AM
Rockpick's Avatar
Moderator &
Bummer...
Old Apr 15, 2005 | 09:18 AM
MikeF150's Avatar
litnfast... there are some good tips over at the roadfly detailing forum on using Langka/Mothers chip repair... http://forums.roadfly.org/forums/detailing/ (Do a search on "Langka")
Wait 2-4 days for the paint to dry and try diluting a little of the Langka solution with a couple drops of water (you may have to try a few combinations starting with most diluted first....) Supposedly, a diluted solution won't pull the paint out ....
Lots of other good detailing tips/tricks at the site as well.... some very knowledgable detailing fanatics on the forums...
