Backglass Trim
Hey RP,
I quickly scanned your thread since I don't have a lot of time right now but I have some quick questions.
How are those 9mm bolts securing the glass? The reason why I'm trying to remove the outside trim isn't just for fun but I tried to use those bolts as mounting points for a pretty heavy amp (around 40lbs) and they broke off like little matches. What I'm needing to do here is drill from the outside into the cab and replacing them with heavier gauge bolts.
Do you have any suggestions?
