scratehes...
Old Jun 12, 2004 | 06:21 PM
Jimmer's Avatar
Thumbs down scratehes...
Well folks I must have picked up some grit of some kind last waxing, found these today,when washing .. Nasty scratches...
here are some Pics...
Ok Shine doctors what do I use to get rid of these...
Old Jun 13, 2004 | 12:23 AM
MaxTorque02's Avatar
I would imagine Meguiars Color X should take those out no problem. Follow up with a coat of wax and you should be good to go.
Old Jun 13, 2004 | 05:23 PM
Rockpick's Avatar
Moderator &
COLORX should be an adequate fix in my opinion as well.
Even better, with COLORX, you won't have to follow up with a wax product at the end as COLORX is an 'all-in-one' product that works GREAT!!!
The trick will be to 'work' the product until it's starting to dry. You won't be able to simply smear it on and come back to it... keep rubbing it in and then remove it after it's dried.
Give it a whirl. For $5/bottle, even if it doesn't have enough power to work through that scratch, you're not out much cash.
As always, if you have troubles or if the product doesn't address the scratch, let us know and we can step you up to something a bit more agressive.
RP
