Underbody cleaning
Old Mar 8, 2004 | 01:26 AM
Johngs's Avatar
Underbody cleaning
Mine is pretty freakin dirty
What would be a good way to clean this? There is some surface rust in some places, but nothing serious from what I can tell.
Old Mar 11, 2004 | 06:12 AM
rkjerue's Avatar
I found a quick and easy way to really clean under your truck at home. Spray frame and any parts of the underbody with Castrol Super Clean Cleaner/Degreaser and attach your hose to your hot water heater and hose it off, it will look like it just came off the assembly line, no kidding I do it every 4 to 6 months and it work's great.
Castrol Super Clean Cleaner Degreaser Link:
http://www.castrolusa.com/products/p...&product_id=44
Old Mar 12, 2004 | 04:26 PM
chknbone's Avatar
rk,
doesn't that also wash away the lubricants that you want under there? (joints and stuff?) Or all they all protected?
chknbone
Old Mar 12, 2004 | 09:51 PM
Rockpick's Avatar
Moderator &
I use the same method that was described with the degreaser... I try to pay very close attention to areas that are lubricated to keep the degreaser off of them...
Also, I utilize a pressure washer...
That might be tomorrow's project for me...
RP
Old Mar 12, 2004 | 09:59 PM
01 XLT Sport's Avatar
You mean to tell me you all don’t jack the truck up and crawl under there after washing it each weekend? Damn, no wonder my neighbors think I am nuts…
Neighbor walks over and ask:
What are you doing under there?
Me:
Polishing my shaft...
Neighbor:
RUNS OFF, what a chit head neighbor...
Old Mar 16, 2004 | 08:34 PM
TonyPTX's Avatar
Me:
BWAHAHAH!!!
Old Mar 17, 2004 | 10:43 AM
Green_98's Avatar
what are some of the obvious areas that shouldnt be hosed down with this cleaner?
Old Mar 17, 2004 | 11:28 AM
TonyPTX's Avatar
I would stay away from ball joints and any axle/drive shaft joints at the back of the transmission and front of the bell housing of the rear axle. It couldn't hurt to pump a shot or two into all the ball joints after cleaning to ensure they are packed w/grease.
Speaking of which (does Ford provide grease fittings as stock?) I can't recall that right now and my truck is at the garage 3/4 mile away.
TonyPTX
Old Mar 18, 2004 | 10:40 AM
Green_98's Avatar
i think that Ford provides a few grease zerks but im not sure where/how many. I know alot of people complain that there are not enough fittings and when they run dry, they get reemed by Ford for high cost of replacement.
Old Mar 18, 2004 | 01:36 PM
TonyPTX's Avatar
Drill-n-Tap?
My old man used to be a millwright and he always had a drill and tap set in his back pocket. He could drill and tap a bearing faster than it would take most of you to pull the tire off of a car. If you have a steady hand and the right tools, I guess you could put them in yourself. Now a days, most of those joints are sealed and supposed to be "life-time, self lubed" joints.
Tony
