Meguiar's Citri-Gel
Old Feb 17, 2004 | 11:10 PM
Rockpick's Avatar
Moderator &
Meguiar's Citri-Gel
Another product that I was able to try this past weekend was Meguiar's Citri-Gel. This product is part of the 'Detailers Line' of Meguiar's products and is only available by the gallon (or case of 4, 1-gallon containers).
This is a multi-purpose cleaner that was recommended to me by Boss_429 and, yet again, he was dead on with this product recommendation!
I purchased the Citri-Gel from [http://store.premiumautocare.net/mecimucl.html]Premium Auto Care[/url] for $15.95 for a gallon. As you know, buying in bulk is a HUGE advantage from a cost standpoint... this is no exception.
I used the Citri-Gel on all of my tires and my wheel wells (which were HELLISHLY DIRTY). I allowed the gel to sit on the tires for about 4 minutes and I gently aggitated the gel with a nylon bristled brush. After another 2 or 3 minutes, I rinsed the wheels with a steady stream of water. To my astonishment, the wheels were nearly PERFECT!! I repeated this procedure in the wheel wells and I couldn't believe the amount of 'goop' that poured out of the wells.
Once dry, I noticed that the wells were nearly clean enough to eat off of!!! I went back over them with some Meguiar's #40 Vinyl Protectant and they looked like they were BRAND NEW!
This is a great product! You will need to furnish your own spray bottle with a 'high-volume' type of spray nozzle as it is a 'thicker' product that is designed to be sprayed (when it hits it's mark, it sticks, very little running like Westley's Bleach White etc..).
Give it a try the next time you need a very high-quality multi-purpose cleaner. The next area that I plan to tackle is the engine compartment...
RP
Old Feb 18, 2004 | 05:54 AM
Boss_429's Avatar
Glad you like it RP. I love how you can spray that stuff on, let it sit for 5 - 10 minutes, and it is still on there emulsifying the dirt when you come back to it!
Are you diluting it at all?
Old Feb 18, 2004 | 08:43 AM
Rockpick's Avatar
Moderator &
Forgot to mention that... I'm going 2:1.
Old Feb 18, 2004 | 06:49 PM
normikg's Avatar
Will this stuff work on the KR running boards?
Ron
Old Feb 18, 2004 | 07:21 PM
Boss_429's Avatar
Ron
Ron,
It says on the web site that it's safe for aluminum, paint, rubber, and plastic. It's also safe for use in the engine compartment. Therefore, I don't see why you couldn't use it on the running boards. I would try a little first though, just to be sure.
Old Feb 18, 2004 | 07:27 PM
Rockpick's Avatar
Moderator &
Yep... it'll work on the KR Running Boards.... no problem. I'm not sure how well it'll work on the 'texture' of the vinyl though... you'll definately have to hit it with a brush or something to work the stuff down into the texture...
RP
