Bedliners, Caps, Tops & Lids
One man shell removal/install
Old Apr 14, 2015 | 08:18 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
My hightop camper won't fit in the garage so I couldn't use a hoist.
I built two saw horses slightly higher than the bed rails and a couple of ten foot beams.
Park the truck where I want the camper and set a saw horse on each side.
Unclamp and lift half the camper a few inches, slide in the beams.
Slide the beam until the camper is clear and drive out.
Reverse to install.
Old Apr 14, 2015 | 08:32 PM
Roadie's Avatar
That's some good thinking!
Old Apr 14, 2015 | 10:49 PM
2wd? your truck still stock suspension? Looks like the rear is sagging a bit?
very ingenious setup
Old Apr 15, 2015 | 10:21 AM
Raoul's Avatar
25 Year Member
2wd? your truck still stock suspension? Looks like the rear is sagging a bit.
I posted the pics backwards hoping not to get caught.
It's actually a cap install.
I had just finished hauling three yards of top soil. (3 trips)
She's got her butt back up in the air now.
Old Apr 18, 2015 | 09:07 AM
RevBiker's Avatar
Very Kool. I would run some tie downs on the horses to the ground and the cap so the wind will not blow it over! I wish I have this when I had my cap. I may go and buy another cap and build one of these. You could use those screw archers in the ground they use for dogs cables. Drill holes in the upper 2x4's and run pins or long bolts into the horses, then clamp the cap to them. Just some added ideas.
Old Apr 18, 2015 | 11:56 AM
Raoul's Avatar
25 Year Member
I put mine in a protected spot.
It's only off from around November thru January, so I can do this...
