Bedliners, Caps, Tops & Lids
Looking for topper weather seal recommendations.
Old Jan 18, 2010 | 10:20 AM
kola's Avatar
Hi:
I recently purchased a used Raven topper for my 2002 F-150 extended cab. I plan using the topper only when I go camping, so I will probably will be putting the topper on the truck and taking it off a few times a year. I'm looking for an effective/durable weather seal that I won't have to replace every time I want to put the topper back on the truck. I have seen the inexpensive seal tape (link below) but it doesn't look very durable.
I'd appreciate any recommendations.
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Old Jan 18, 2010 | 11:24 PM
ruffn-it's Avatar
It looks like the stuff that was used on my 01 screw's are fiberglass top(mine may have been a tad thicker hard to tell from pic)...I took it on and off several times over 5 years or so and it did fine. I think you would only have a problem if you left it off for a while and let the elements get to it. And it would also be more prone to you snagging stuff on it and ripping it up/off.
Old Jan 30, 2010 | 08:05 PM
LabMan12's Avatar
I use a product like that. Works great for the side but it doesn't seem to matter how I try doing it, but it always leaks at the front. I am going to try resealing again this spring.
Old Jan 30, 2010 | 09:20 PM
B&WScrew's Avatar
I used a double hump seal from cargogear.net If I remember correctly, it ran about $1.20 a foot. I take my cap off to switch to my tonnoue cover a few times a year. I use the normal truck bed seal(1/8" thick closed cell foam) for the soft cover.
Old Jan 31, 2010 | 11:12 AM
kola's Avatar
Thanks for the replies. I'll definitely go with the more durable rubber seal.
