Bedrug Help
Bedrug Help
Hey guys. So the sides of my bedrug are coming off and sagging down just below the bedrails. What should i use to make them stay on the sidewalls? I tried some velcro that I got at Ace Hardware, but it too came off. I want something to keep it permentally attached to the sidewalls. Thanks!
Just call Bedrug 1-800-462-8435 they will send you a new install kit. How long has it been in your bed? If it is just the velcro not sticking to the bed then it is most likely an installation issue. 3M tape is very temperature sensitive (needs to be atleast 65-70 degrees) and you must clean the surface well for it to adhere correctly. Alcohol is best it will remove all contaminates and wax (don't clean it then put wax on it to protect it), and you need to use a good surface prep/primer, the new install kits will have this included.
