Bedliners, Caps, Tops & Lids
Suggestions for new velcro for bedrug...
Old Apr 23, 2007 | 10:28 AM
thais0n's Avatar
I got my truck with Line-X, but then decided later to put a Bedrug in. I got some super industrial strength velcro, and its losing its stick. Should I just get the replacement Velcro from Bedrug directly? (I bought mine used so I didnt have the original velcro). Or can you guys suggest a better kind of velcro. Its the adhesive on the back of the velcro that is causing me problems - its like it wont stick to the line-x.
Old Apr 23, 2007 | 10:47 AM
TruckGasm's Avatar
Buy this:
Old Apr 23, 2007 | 11:03 AM
Bryndon's Avatar
TruckGasm hit that one on the head - it's the texture that makes it not stick - the adhesive will not only stick, but fill the texture.
thais0n's Avatar
Wont that make it permanent???
Old Apr 23, 2007 | 11:13 AM
Bryndon's Avatar
Use it on the velcro - the velcro will be permanent.
Old Apr 23, 2007 | 12:11 PM
thais0n's Avatar
Oh ok, I got it.
Would any stores sell that, or is pretty much an online-only product?
Old Apr 23, 2007 | 12:34 PM
TruckGasm's Avatar
I've seen it in Pep Boys. I buy a larger tube at a professional paint store.
Old Apr 23, 2007 | 02:43 PM
thais0n's Avatar
I am buying the replacement velcro kit from Wise Industries, and they recommended using an adhesive promoter. I might try that first...if it fails, I will move to the 3M stuff.
Old Apr 23, 2007 | 03:28 PM
TruckGasm's Avatar
I use the 3M stuff to stick the LINE-X warranty tag on LINE-X. Regarding the LINE-X surface, I suggest you clean the surface first with denatured alcohol, methanol, or acetone in order to degrease it. Then use the 3M stuff.
Old May 11, 2007 | 09:14 AM
The_Beast's Avatar
The 3M would be the way to go to fill the texture and make it a smooth surface for the tape to adhere to. The other option would be to sand the line-x material to smooth out the texture and give the Velcro backing tape a good surface to adhere to.
