Bedliners, Caps, Tops & Lids
Bed Bolts and Spray Liner
Old Mar 12, 2006 | 03:43 PM
todd edwards's Avatar
the bed bolts are made of aluminum i think.so they won't rust.
Old Mar 13, 2006 | 02:00 PM
JS2003's Avatar
Hmmm... I wouldn't have thought aluminum was strong enough.
Old Mar 13, 2006 | 02:28 PM
Bryndon's Avatar
There are certain grades of aluminum that could be used - at ridiculous expense. The bolts - although I haven't looked lately - are most likely galvanized steel. It holds up better than zinc plating, but eventually will likely show some rust spots.
Sprayed bolts are only an issue if you get wrecked and while there are ways to repair spray-ins, they rarely look good when done.
Old Mar 21, 2006 | 11:42 PM
i have 4 aluminum wheels my 5000 lb truck is setting on.pretty strong.just kidding.galvanized sounds like it would be correct.
Old Mar 23, 2006 | 04:26 PM
Eastrick's Avatar
Maybe not...
A lot of automotive fasteners use a thin paint-like protectant called Magni-coating. It is thin enough that it allows the use of standard nuts, whereas galvanized bolts require the use of oversized nuts. The magni-coating is also available in several colors as well as silver, which looks similar to galvanizing, but even more like a dull aluminum.
We use bolts with a Silver Magni 555 coating at my company, that is how I found out about it.
Check out www.themagnigroup.com if you are interested in more info on anti-corrosion coatings.
-CJ
