Bedliners, Caps, Tops & Lids
Stock bedliner
Old Feb 21, 2006 | 08:13 AM
dixieF150scab's Avatar
Stock bedliner
I was wondering if anyone has had problems with bed rusting because of stock drop-in bedliners? I have heard that drop-ins can promote rusting. I had an aftermarket over-the-side liner in a Nissan pickup and took it out and waxed the bed every year to prevent this. I never had a rust issue, and was wondering if the stock bedliner in my 2004 F150 will pose a problem. Frankly, I'm not a big fan of the spray-on liners and want to keep what I have, but would ditch it if it will rust out the bed. Any input? Thanks.
Old Feb 21, 2006 | 09:22 AM
Bryndon's Avatar
They don't promote rust, but they do chafe the paint. If enough paint gets removed, you could get rust. Strangely, the more you haul in a drop-in liner, the less they chafe - the weight of the load keeps them from moving around.
It's probably worth buying a paint protector for under the drop-in, then rust is very unlikely - it's probably also worth taking it out occasionally to clean and check for damage... not necessary (generally) but hey, the truck is worht something!
Old Feb 21, 2006 | 11:02 AM
vader716's Avatar
I have a linex, with that said...
I dont think a drop in is necessarily bad. If years down the road you have a problem with rust you can always have a spray in added then. THe prep process for the sparyin will remove some rust anyway.
Stick with what you like
Old Feb 23, 2006 | 01:38 PM
worland's Avatar
My '97 SCAB had the factory drop in bed liner. I pulled it out last June because it cracked along the bed rails. There was a rubber mat under the liner. There was just a little chafing along the bed rails. Considering the truck sits outside, and spent most of its life in SC & NC, I was pretty amazed there was no rust at all. I also had the stainless steel bed rails installed, so it pretty much kept the bed liner in place and prevented it from moving around.
