line-x problem
traveled to nearest dealer to have my 01 screw sprayed.looked great at first then 2 days later the bubbles started appearing all over.some bubbles are 3x4 inches,about 20 in all.called the dealer back and said he would take care of it. the bummer is i live 1.5 hours from the dealer.anyone know why this would have happened
I think I do. You have to heat up the bed of the truck, usually with one of those "turbo" heaters so that all of the moisture is evaporated from the surface right before it's sprayed. If you don't, when the hot liner is sprayed in, it will evaporate the moisure on the surface which causes a bubble.
It could have been caused by a chemical on the surface that reacted to the bedliner or they didn't get it dried out completely. I empathisize with your problem but your Line-X dealer will fix the problem no questions asked. Sorry you have such a long drive.
