Mirror reflectors turned into turn signals how to w/pics
Old Mar 30, 2010 | 06:52 AM
F_ast's Avatar
Awesome, is pretty much the only way to sum that up. Great job and nice write up... You sure do like your lights. This might be another one I have to do over the summer. The first being addition of reverse lighting.
How does the LED strip mount? You glue it in?
Old Mar 30, 2010 | 08:33 AM
tbraquet's Avatar
Originally Posted by F_ast
...You sure do like your lights. This might be another one I have to do over the summer. The first being addition of reverse lighting.
F_ast, Yes I do like lights. The LED strip is mounted by the adhesive tape on the back of the LED's. The strip has it already.
Old Mar 30, 2010 | 08:42 AM
BrainDonor's Avatar
nice job and nice write up!
Old Mar 30, 2010 | 08:58 AM
foxracer2759's Avatar
nice job i really like it, looks like they came stock like that on the mirror. to bad i already put the black filler caps for the reflector spot in. really like it though looks real good
Old Mar 30, 2010 | 01:56 PM
mack63's Avatar
Damn I just had my mirrors apart Sunday to add the OEM turn signals to the other side of my mirrors on my STX. Looks like I will be taking them apart again. I already bought the amber reflectors. Nice job!
Old Mar 30, 2010 | 02:20 PM
che22879's Avatar
nice job! I need to find a set of 09+ mirrors to do this on my 05.
Old Mar 30, 2010 | 04:51 PM
sharper4's Avatar
This is way better than my vision of doing this. I'm totally stopping by AutoZone on my way home. VERY good write-up and awesome job (with both the mirror and under the headlamps).
Old Mar 30, 2010 | 05:13 PM
ibcop's Avatar
Great job!
Old Mar 30, 2010 | 05:29 PM
nshipley's Avatar
Man that is pretty awesome, and frankly I am pissed at you for adding another project to my list of things to do. :-)
I do have one question - during the day, with the turn signal off, how does the reflector look since you cut out part of the white backing? I am just curious if you can see your cuts through the reflector. Is there a way that you could remove all of the white reflector backing? I guess if you did that then you would see the edges of the LED strip.
Let me know your thoughts. This is a pretty cool mod. Between this, the lights I want to add under my back bumper, and the lights I added in to my tool box, I think that will be enough lights for now. :-)
Old Mar 30, 2010 | 06:37 PM
bankrpt's Avatar
i just got done doing mine on my 04 took about an hour and half and LOVE them they are sweet and yes i have 09-11 mirrors on my truck
https://www.f150online.com/forums/20...s-my-04-a.html
blinker off
blinker on
Old Mar 30, 2010 | 06:52 PM
rednoved's Avatar
That turned out great! Do you have any pictures of the led strip or how you applied it to the back of the reflector?
Old Mar 30, 2010 | 07:08 PM
bankrpt's Avatar
there is 3m tape on the back of the led strip just press it on the mirror
Old Mar 30, 2010 | 07:47 PM
09STX's Avatar
Is the turn signal wiring in the mirror already on the STX or did you need to wire it?
Old Mar 30, 2010 | 07:59 PM
redfx4150's Avatar
I think this has real trun out great and I thing I will be doing the same this weekend, the only thing that could make this better is if it worked with the parking lights just not the turn signal
also them little led from auto zone are bright i have them as my under dash and seat lighting but in blue
Old Mar 30, 2010 | 08:18 PM
tbraquet's Avatar
During the daylight you can not tell the white backing was cut out. Also you can not remove the white backing completely; it is glued onto the reflector and as far as I can tell if you try it will break the reflector.
The clearance after the hole is cut for the LED's is perfect for the LED strip. The strip fits almost flush when inside the hole. Even if you did not use the 3M adhesive tape to stick it to the housing, the LED would not move around if you cut slit just enough for the strip to fit.
