09-10 mirrors on my 04
Old Feb 11, 2010 | 08:27 PM
bankrpt's Avatar
i just got done installing my 09-10 mirrors with turn signals everything works but the turn signals the mirrors i did have had the turn signals so i know the truck is wired for turn signals i just dont know how to get them to work anyone have any suggestions i was thinking if i had to wire it from the turn signals in the headlights to make them work what ya'll think?
Old Feb 11, 2010 | 08:35 PM
thejake1989's Avatar
no clue im just here for pics later
Old Feb 11, 2010 | 08:39 PM
expedition4x4's Avatar
x2 but i think i remember somebody saying you had to move one of the wires around from the mirror plug
Old Feb 11, 2010 | 09:19 PM
bankrpt's Avatar
not the best i have one of each mirror on the truck can you tell which one it is?
Old Feb 11, 2010 | 09:34 PM
drivers side
Old Feb 12, 2010 | 08:52 AM
kingfish51's Avatar
I believe you have to move some of the pins to get everything to work. Do a search, it has been detailed on what has to be done.
Old Feb 12, 2010 | 01:43 PM
bankrpt's Avatar
Yeah probably all it will probably be just as easy to wire directly from the turnsignals in the headlight
Old Feb 12, 2010 | 02:02 PM
kingfish51's Avatar
It will probably be easier to just swap pins rather than running lines from the turn signals. It is already there, just has to be moved to the proper slot.
Old Feb 12, 2010 | 04:03 PM
City of Champs's Avatar
put a test ligt in the pins in your miror harnaess with your left signal on. should be easy enough to find the answer.
Old Feb 12, 2010 | 09:49 PM
GoRacer's Avatar
That looks good, so the turn signal is in front part of the mirror assebly, opposite of the older version just below the mirror glass?
Old Feb 12, 2010 | 10:22 PM
bankrpt's Avatar
no thats a reflector that comes on the higher end f150s the turn signal is in the same spot as the old ones that reflector can be removed and you can put the plain black piece in the spot of the reflector i have a little trick up my sleeve im doing with the reflectors
Old Feb 14, 2010 | 02:07 PM
bankrpt's Avatar
Well guys and gals i finally got the turn signals to work without swapping pins around or even running wires from the turn signal to make them work what i did was actually get the 04-05 mirror wire harnesses from a wrecked truck and took the 09-10 mirrors apart and swapped the harnesses out and they WORK!!!!!
Old Feb 14, 2010 | 02:13 PM
150 flareside's Avatar
Just logged in, all you had to do was add a ground wire for the directionals to work. Have the 09 mirrors on my truck. I wish I could get the heated mirrors to work .
Old Feb 18, 2010 | 09:16 PM
Tim4717's Avatar
Where?
Can anyone tell me where to buy a set of these? I would like the turn signal and would definitely try to wire up the heated to work off a toggle switch or something. Erie, PA weather just showed me once again how bad it sucks not having heated mirrors lol.
Old Feb 18, 2010 | 09:30 PM
jsvo5695's Avatar
Bankrpt - Are you going to paint the front bumper?
