Charging/Electrical System Big 3 Upgrade (Extremely Pic-Heavy)
Old Apr 1, 2010 | 07:52 PM
jbrew's Avatar
Originally Posted by coobies5
nice cover up
it gets the best of all of us
Bonehead
Old Jul 7, 2010 | 01:34 AM
StoveTop's Avatar
Picture Links Need Updating
I am planning on doing this mod this summer and just saw the links to the pics need updating.
Thanks!
Old Jul 19, 2010 | 06:05 PM
mblouir's Avatar
Sorry for the delay guys....I've been inactive for a while. I'll go out tomorrow and shoot some pics of what I have. While it won't be as in-depth as the previous pictures, it should help out enough to get the job done.
Old Jul 21, 2010 | 09:35 AM
mblouir's Avatar
Here are the new pics. Not as in-depth as before but hopefully they are enough to help. The pictures should be self-explanatory when it comes to cable locations, but let me know if you have any questions. I'll repeat what I said in the original post: this isn't a set-in-stone way....it's the way I did it.
Old Jul 21, 2010 | 12:36 PM
jbrew's Avatar
Nice, but mannn, -you need a junction box for all that lol. There must be something you can do without having to tie everything to the posts. I spliced/soldered mine before the posts. Nice pics, Great! But man, that's gottuh bug you a little at the posts ?? Don't it ?
Old Jul 21, 2010 | 04:50 PM
mblouir's Avatar
I'm likely going to go back and redo some of it when I get some more time, for sure. Lately I just haven't had the free time to work on the truck that I used to.
Old Jul 21, 2010 | 11:30 PM
jbrew's Avatar
Good clean job, about as clean as you can get.
Old Jul 22, 2010 | 12:05 AM
mblouir's Avatar
Thanks, man. I tried to keep it as clean as possible working with what I had available.
Old Aug 11, 2010 | 08:33 AM
sonicwrx's Avatar
im going to do this this weekend but i have a question. i have proven to myself i suck at soldering. so can i get some tips or exactly what i need to buy in materials anything will help.
Old Aug 11, 2010 | 01:11 PM
mblouir's Avatar
For the soldering, I'd recommend finding someone who has a bench vise you can use. It makes it a lot easier in both holding the wire steady and in crimping the lugs on.
As for soldering itself, I'd suggest a roll of thick solder and a mini propane torch. With cable this size, it would take forever to use regular thin-wire solder and a little touch-based solder gun.
Pictures speak louder than words, so instead of the first picture, do the second picture. If you can find thicker solder, great.....if not, as long as you have the propane torch it will work.
When you go to solder this way, keep the flame on the backside of the lug. You want to heat up the metal of the lug and cable enough to make the solder melt and seep down between the strands of cable. It makes for a much stronger connection. Also, this comes after the crimping.
This may or may not help, too:
http://www.youtube.com/watch?v=gBDdbALcgeU
Old Dec 16, 2010 | 04:59 PM
KJD09's Avatar
Originally Posted by mblouir
here are the new pics. Not as in-depth as before but hopefully they are enough to help. The pictures should be self-explanatory when it comes to cable locations, but let me know if you have any questions. I'll repeat what i said in the original post: This isn't a set-in-stone way....it's the way i did it.
where do the other wires run from the alt?
Also my truck grounds run towards the tranny? Am i following the correct set comming off of the battery?
Old Feb 16, 2011 | 09:31 AM
JakeKo's Avatar
Question......
This even seems like overkill to me, I know, you don't need to reiterate.
I have a chance to grab some ginormous cable from where I work. I mean, this stuff looks bigger than 1/0 AWG. Anyone think something will go wrong if the cable is too big? Pass too much current? Or is there no worries? This stuff is seriously huge, and I have a way to get terminals for my battery and such so its not a problem. I mean.....it's free, so why not.
Thanks guys
Old Feb 28, 2011 | 09:10 PM
mblouir's Avatar
Don't take my word for it, but I don't see any problems with using bigger cable as long as it's quality. The only issue I see arising is flexibility, but our engine bays are pretty big.
Old Jul 28, 2012 | 03:10 PM
helotaxi's Avatar
Old thread I know but the last question was never answered...
It is impossible for the wire to be too big. Current flows in accordance with demand and bigger wire simply means that you lose less voltage when higher current is demanded. That means that the wiring is more efficient. More efficient wiring is whole point of this upgrade.
Old Nov 8, 2013 | 01:43 PM
Kongfish's Avatar
Hi,
Can you help me to be able to see the photos in your post on the three big grounds. I am getting a empty square with no photo in the box. The instructions don't say exactly where these grounds are located at, i need to see pictures of the: (engine to chassis,) (battery to chassis) (battery to Alt. ) i check back this evening to see if you posted them to my reply.
Thanks,
Gary
