Steering Stabilizer DIY Installation
Old Mar 2, 2015 | 09:37 PM
trkfrd05's Avatar
Fabtech stabilizer kit
I was told unless you have the 6" lift the kit won't bolt on. Is it possible to have the brackets welded in a alternative location to get them to install and function correctly? If anyone has tried this or knows your input would be appreciated. Thanks in advance.
Old Dec 18, 2020 | 03:12 PM
MAD2024's Avatar
Steering stabilizer for 2014 F150 4WD FX4
I see that this was an easy install and I have goggled the Fabtech FTS8009 stabilizer. Per everything I've seen this will not fit my truck? Does anyone know of a stablizer that will? I have a 6" lift with a set of 35" tires and am concerned about issues on rough roads.
