The Official Leather Install Guide w/pics
Old Mar 15, 2008 | 10:26 PM
05RedFX4's Avatar
Finally completed the install of my Katzkins leather in my Scab FX4. It took me 2 days, stopping to take pics, 48 of them.
Start by depressing the hidden button to remove headrests
Pop off acess cover on seat belt cover box
Remove two 10mm nuts and pull off cover
Old Mar 15, 2008 | 10:27 PM
05RedFX4's Avatar
Depress clips and pull out rear seat back
Flip seat back over and remove headrest tubes
Depress button on tubes and push them out, paying close attention to location as they will only fit in the original location
Old Mar 15, 2008 | 10:44 PM
05RedFX4's Avatar
Peel off seat cover, the rear seat back has 9 hogg rings across the horizontal seam that need cut.
Rear bottom cushions, remove plastic clip between the cushions
Remove T-50 torx bolt
Remove phillips head screw and pull off cover plate to reveal second T-50 torx bolt
Now pull out rear cushions, you may have to twist and swear, but it will come out. It helps to pry the cusion off of center pivot pin with a long flat screwdriver.
Old Mar 15, 2008 | 10:49 PM
05RedFX4's Avatar
Separate J-clips and pull off seat cover, one corner has a velcro seam to aid in removal
stop peeling cover at this point
Cut and remove hogg rings, the rear 40 has 3 rings, the rear 60 has 6
Old Mar 15, 2008 | 10:54 PM
05RedFX4's Avatar
Finished rear cushion
Now reinstall rear seat in reverse order of removal.
I modified the infamous clips so future removal will be easier
Old Mar 15, 2008 | 11:05 PM
05RedFX4's Avatar
Front seats, Start by removing four 13mm nuts under bottom cushion, one on each corner. Unclip harness connectors, and pry push pins on harness to get bottom cushion out.
Remove and save the two push pins on the underside of seat cushion, you need to reuse them on new covers
Old Mar 15, 2008 | 11:13 PM
05RedFX4's Avatar
After unclipping cover, peel back cover to reveal hogg rings. Ther are 9 rings total, 3 across the back seam, and 3 on each side.
The bare cushion
Turn new cover inside out and start attaching with new hogg rings, back seam first, then sides.
Old Mar 15, 2008 | 11:14 PM
02SuperCrew4X's Avatar
And then clean out that truck when you're done!
Old Mar 15, 2008 | 11:20 PM
05RedFX4's Avatar
After attachment, fold over corners while turning cover right side out. attach clips to the underside.
Finished cushion
Remove 18mm nut, unhook seat belt anchor
pop out cover plate
Old Mar 15, 2008 | 11:28 PM
05RedFX4's Avatar
Remove four T-27 torx bolts, two on each side.
Now slide off seat belt cover to reveal a fifth T-27 torx bolt on seat belt guide plate, remove that also.
Now unhook J-clips under seat back and start peeling upward. Stop at this point
Old Mar 15, 2008 | 11:35 PM
05RedFX4's Avatar
Ther are 3 hogg rings on the front side, and 2 on the back, cut and remove.
Now pull cover the rest of the way off, being careful around headrest posts so you don't tear seat cover. Reach up inside seat back from the backside and depress clips on headrest tubes and pull out, set them aside for reuse.
This bolt needs to be removed, it's a 15mm
Old Mar 15, 2008 | 11:38 PM
05RedFX4's Avatar
Remove this bolt also, it's a 13mm
now wiggle, pull, tug to get seat belt mechanism out
Seat should look like this now
Old Mar 15, 2008 | 11:44 PM
Droog's Avatar
Great thread, keep it coming.
Old Mar 15, 2008 | 11:51 PM
05RedFX4's Avatar
Bare naked seat frame
Now install new cover, reverse of removal. If you have aftermarket covers or screw covers you now have to cut a hole for the seat belt on the top of the seat back. This is only needed if you are installing new covers in a scab or reg cab as they have the seat belt in the seat. OEM covers for a scab has the holes for the seatbelts in them.
Aftermarket covers, such as katzkins do not have the holes for the seat belt or the headrest tubes, you have to cut them. Does not matter what body style you order, that's how they are.
Also, if you are doing an install in a screw, you DO NOT need to unassemble the seat belt, just yank the old cover and install the new.
Now reassemble seat belt and seat, bolt bottom cushion back in and plug harnesses back in, your done.
Old Mar 15, 2008 | 11:57 PM
05RedFX4's Avatar
Finished
