Shaved Tailgate w/ Hidden Handle
Old Mar 22, 2011 | 11:49 PM
Shaved tailgate, without buying a relocation kit
My new handle
mount the bracket on the bottom of the bed side.
Basically drill a hole up through the tailgate inner supports.
flip handle over 180* Will take a little bit of work to resync the pull rods to the handle mechanism
secure the cable to the hole in the handle
since the original handle mechanism mounts to the backside of exterior handle, i used shortened 10mm bolts and J nuts to secure it to the tailgate frame
You will need to always leave it in the unlocked position, unless you also setup for the electronic lock actuator on the black lock lever
Oh and the "handle" is a "carb choke cable kit" from Advanced Auto, i had to shorten it some, but leave a little extra on the cable in case you break it when you are twisting it to the tailgate handle.
Old Mar 22, 2011 | 11:54 PM
Neat Pat!
Old Mar 23, 2011 | 01:24 AM
dirtyd88's Avatar
No more pull string (wire)!
Glad to see you finally got it fixed up good.
Old Mar 23, 2011 | 12:20 PM
1fast4.6's Avatar
Im going to try an eletric door popper on mine with a push button somewhere on the inside of the bed. If that dont work this should!
Old Mar 23, 2011 | 04:18 PM
ShavedBlack07's Avatar
This seems like a pain in the *** if anything. Personally i'd be worried about someone finding it and stealing your tailgate. I'd use the relocator kit. There only like $75 and comes with the right bracket and a weld plate plus you can use the factory handle so you can lock it still! Cool idea but I dont trust people enough to do that.
Old Mar 23, 2011 | 10:28 PM
well any tailgate locked or not can be stolen by taking off the interior panel and opening the lock and handle from the inside.....
Actually this makes it harder to steal because most people can't find the handle, and if they did, they would have to unbolt the bracket from the bottom of the bed to take the tailgate
Old Mar 23, 2011 | 10:35 PM
So how high do you have to jack the truck up to open your tailgate.
Nice mod, Patrick! As usual you're thinking ahead of the game.
Old Mar 24, 2011 | 01:43 AM
Captain Awesome's Avatar
nice.
Old Mar 24, 2011 | 04:02 PM
floridean's Avatar
Do think you'll still like it in a couple months seeing as you have to bend down and reach under to open it? But i guess it makes up for that in Bad A**ness!
Old Mar 24, 2011 | 07:56 PM
its actually been on for a year like this
just had a request to do a write up on it, on another forum, so i copied it here as well :o
Old Mar 26, 2011 | 07:52 PM
Dont have to jack it up, just have to remember to open the tailgate before i back over a curb
Old Mar 27, 2011 | 12:44 PM
GATOR CREW's Avatar
2009 F150online Truck of the Year
Nice work Pat!
Old Mar 29, 2011 | 11:39 PM
Dinggus's Avatar
That is pretty awesome! I was thinking about getting the truck tailgate shaved as well, but then I'd have to get the doors shaved to match.
Old Mar 30, 2011 | 08:11 PM
bagtodrag's Avatar
flush push button also works good too.
Old Apr 1, 2011 | 04:30 PM
STX2005's Avatar
A little confused..
Excuse me for being confused here but is this eliminating the handle on the outside of the truck and adding some sort of pull handle underneath?? If so why? What are the advantages?
