Transmission Information Page
Old Mar 31, 2016 | 02:35 AM
  #106
kevcarr59's Avatar
Thanks JMC, for the link. I happened to get the printout from my VIN from the local FORD truck dealer, and the parts guy showed me the trailer info download on the screen. I did that when we were in the looking process for the trailer, to see what we could tow safely.
With a 15 year old truck, I plan on going through most of the mechanical systems before we do some of the longer trips. I've already changed out the EGR system, since I was having a lot of problems with idle, and all the parts were original factory. The brakes need some work, as I plan on changing out the master cylinder, at the least, and see what happens from there. All fluid systems will be flushed, and changed to Royal Purple synthetic, where applicable.
As I said, I'm going to a trans shop and have them go through the tranny, and add the cooler, with a temp gauge. It's already got Monroe Magnum 60's all around and pulls the trailer fairly well. I have 4 brand new Dextero DHT2 10 ply tires on some new Discount Tires black aluminum wheels.
We'll probably do another local trip, as a shakedown, and then we go from Austin down to Galveston in the beginning of June. That should be about a 220 mile trip one-way, and that's the one I'm really prepping for.
Old Mar 31, 2016 | 03:05 AM
  #107
JMC's Avatar
JMC
25 Year Member
Good luck and safe travels.
Old May 29, 2016 | 09:13 PM
  #108
Davesolo29's Avatar
Ok. I'm new here. I have gone thru this list. Very helpful.
I have an 07 4x2 with a 4.6.
TR code Q on the sticker. So according to the list I have a 4r75e. But that says its for 5.4l.
I'm looking at a used tranny from a 2004 4.6l 4x2 but it has an "A" code which according to the list is an NP435 from an 80-87?
I'm a bit confused?!!
Old May 29, 2016 | 09:29 PM
  #109
Starting in 04, some of the codes changed. By 07, I do believe the 4.6 got the 4R75, that 04 you are looking at is probably a 4R70.
Please keep in mind this guide was written in 2005.
Old May 29, 2016 | 09:41 PM
  #110
Davesolo29's Avatar
So will the 4r70 work for me?
What are the differences?
Sorry. I'm quite new to this still.
Old May 30, 2016 | 10:16 AM
  #111
You will get a better response if you start a new thread in the Transmissions forum.
Old Oct 26, 2016 | 10:18 PM
  #112
Bigtruckdrver's Avatar
Hi all, I'm new to this site and Im not sure what my trans is?
I have an 03 expedition with a5.4 2 valve and it's four wheel drive. I also have a 05 expedition with a5.4 four wheel drive and I'm wondering if the trans in my 03 will go into the 05? That's my trans and that's what I'd on my door. thank you everybody for any feed back
Old Jan 14, 2017 | 05:38 PM
  #113
Kristol Quigley's Avatar
4r70w trans code u
Hello all!! Getting ready to replace my 04 expedition 4.6 rwd 4r70w with one from a 03 expedition 4.6 rwd 4r70w. Are there any alterations I will need to make for this to fit and function properly in my 04?
​​​​​​​Also. I have an 06 4.6 park Ave 4r75w that I hear may work with a few alterations such as valve plate replacement and restricter spring removal. Is there anything issues I can expect to run into if I use the 4r75w?
Old Jun 29, 2019 | 06:38 PM
  #114
DAVID MICHAU's Avatar
Srod inline. 6 300 cu inch.
Originally Posted by adrianspeeder
Manuals
Model: M5OD-R2
Type: Five speed Mazda Overdrive
Years: 88-96 Bronco, F150s
..........97-03 F150s
..........05 F150 (v6)
Engines: 300, 302, 4.2L, 4.6L
Fluid: Mercon
Display:
1.3.(D)
2.4.R
Ratios:
1st 3.90:1
2nd 2.25:1
3rd 1.46:1
4th 1.00:1
5th 0.80:1
Construction features: External Ribs in square patterns
Trans code: M
Model: SROD
Type: Four speed overdrive w/ push down reverse
Years: 80-83(4?)
Engines: 300, 302
Fluid: ?
Display:
P..R..1..3
U
S.....2..OD
H
Ratios:
1st 3.25:1
2nd 1.92:1
3rd 1.00:1
4th 0.78:1
Reverse 3.25:1
Construction features: Aluminum, shifter near back
Trans code: B
Model: NP-435
Type: Four speed non overdrive
Years: 80-87?
Engines: 300, 302, Your mostly gonna find it behind a 300.
Display:
1.2
3.4.R
Construction features: Cast Iron w/aluminum top plate, shifter in top, PTO Pass side
Fluid: 140w
Ratios:
1st 6.69:1
2nd 3.34:1
3rd 1.79:1
4th 1.00:1
Reverse 3.25:1
Trans code: A
Model: T18
Type: Four speed, non overdrive, non syncro first gear
Years: ?
Engines: 300, 302, 351, 460, 6.9L
Fluid: ?
Display:
1.2
3.4.R
Construction features: Cast iron throughout
Ratios:
Gas
1st 6.32
2nd 3.03:1
3rd 1.79:1
4th 1.00:1
Diesel
1st 4.02:1
2nd 2.41:1
3rd 1.41:1
4th 1.00:1
Trans code: F or P
Model: T19
Type: Four speed, non overdrive, syncro first gear
Years: up till 93
Engines: 300, 302, 351, 460, 6.9L, 7.3L
Fluid: 140w
Display:
1.2
3.4.R
Ratios:
Gas
1st 6.32
2nd 3.03:1
3rd 1.79:1
4th 1.00:1
Diesel
1st 4.02:1
2nd 2.41:1
3rd 1.41:1
4th 1.00:1
Trans code F or P
Model: ZF5
Type: Five speed heavyduty overdrive
Years: 87-99 F2/3/450/superduty
Engines: 300, 351, 460, 6.9?, 7.3
Fluid: Mercon
Display:
1.3.(D)
2.4.R
Ratios:
S5-42 (Diesel)
1st: 4.14
2nd: 2.37
3rd: 1.42
4th: 1.00
5th: 0.77
Reverse: 3.79
S5-47 (diesel)
1st: 5.08
2nd: 2.61
3rd: 1.53
4th: 1.00
5th: 0.77
Reverse: 4.66
S5-42 and S5-47 (gas)
1st: 5.72
2nd: 2.94
3rd: 1.61
4th: 1.00
5th: 0.76
Reverse: 5.24
Trans code: 2
Model: ZF6
Type: Six speed heavyduty overdrive
Years: 99-06 F-superduty
Engines: 5.4, 6.8, 7.3, 6.0
Fluid: Mercon
Display:
R.1.3.(D)
L.2.4
Ratios:
L 5.79:1
1st 3.30:1
2nd 2.10:1
3rd 1.31:1
4th 1.00:1
5th 0.72:1
R 5.23:1
Trans code: 6 (diesel), 5 (gas)
Adrianspeeder
The transmission marked as the SROD for the 80 81 82 83 ?84 was the
Clark RUGG. 3 speed with Overdrive as the fourth position and the shifter was a top positioned box with redirected shift arms to exclude the outside shift positions which were pivot bolts for the shifter arms inside.
In my opinion that transmission is a piece of **** and is not worth the rebuilds I put in mine.
Three times.
And finding a case that was NOT shattered by exploding gears due to excessive input output shaft play after wearing.
Mine cracked from the input shaft to the magnet and drained all the 90 weight on the dirt....never got a good rebuild after that.
Old Jan 30, 2021 | 08:11 PM
  #115
Shane Keddie's Avatar
drive list
With all the posts on what trannys are what, or "what do I have" I thought it would be a good idea to make a total list for the full size fords. Just now I wipped this up to start off, but will keep workin. Please post any corrections ya'll see so I can edit.
For the engine listings. I'll break the common bell housing patterns in {}.
Heavy Duty Automatics
Model: C6
Type: three speed non electronic
Years:
'66-'90 F-series
'78-'89 Bronco
'91-'96 ('97?) F-2/3/superduty
Engines:{300, 302, 351w, 351c}, {400, 351m, 460}, {6.9L, 7.3L IDI}, {352, 360, 390, ect.}
Fluid:
Pre '77: Type F
Post '77: Mercon
Display: PRND21
Pan 17 bolts "Utah" shape
Ratios:
1st 2.46:1
2nd 1.46:1
3rd 1.00:1
Trans code: K
Model: E4OD
Type: Electronic Four speed Over Drive
Years:
'89-'96 Bronco,
'89-'98 F-Series
Engines: {300, 302, 351w}, {460}, {7.3L IDI}, {7.3L PSD}, {5.4L}
Display: PRN(D)21 w/ overdrive lockout switch
Pan: 20 bolts
Fluid: Mercon
Ratios:
1st 2.71:1
2nd 1.54:1
3rd 1.00:1
4th 0.71:1
Trans code: E
Model: 4R100
Type: Four speed, Rear wheel drive, and 100(x10)lbs of torque
Years:
'99-'01 F-150's (rare)
'99-'04 Lightning's, F-150 7700'
'99-'03 superdutys
'03-'04 gas superdutys
Engines: {5.4L, 6.8L}, {7.3L PSD}
Pan: 20bolts
Fluid: Mercon
Ratios:
1st 2.71:1
2nd 1.54:1
3rd 1.00:1
4th 0.71:1
Trans code: E (gas), 9 (diesel)
Model: 5R110 “Torqshift”
Type: Five speed, Rear wheel drive, and 110(x10)lbs of torque
Years:
'03-'04 6.0L
'05-'07 Superdutys
Engines: {5.4L, 6.8L, 6.0L},
Display: PRN(D)321 w/ tow haul lockout switch
Pan ?
Fluid: Mercon SP
Ratios:
1st 3.09:1
2nd 2.20:1
3rd 1.538:1
4th 1.00:1
5th 0.71:1
Trans code: B
Light Duty Automatics
Model: AOD
Type: Four speed non electronic
Years:
'85-'93 F-150
'85-'89 Bronco
Engines: 302
Display: PRN(D)D1
Pan ?
Fluid: Mercon
Ratios:
1st 2.40:1
2nd 1.47:1
3rd 1.00:1
4th 0.67:1
Trans code: T
Model: 4R70w
Type: Four speed, Rear wheel drive, and 70(x10)lbs of torque
Years: '94-'07 F-150
Engines: {302, 4.2L}, {4.6L, 5.4L}
Fluid: Mercon V
Ratios:
1st 2.84:1
2nd 1.55:1
3rd 1.00:1
4th 0.70:1
Reverse 2.32:1
Trans code: U
Model: 4R75E
Type: Four speed, Rear wheel drive, and 75(x10)lbs of torque
Years: '04-'07 F-150
Engines: 5.4L
Fluid: Mercon V
Ratios:
1st 2.84:1
2nd 1.55:1
3rd 1.00:1
4th 0.70:1
Reverse 2.32:1
Trans code: B ('04-'05), Q ('06+), F ('06+ Mark LT)
What about the 4x4 models you only have rear wheel drive listed
Old Jan 30, 2021 | 10:22 PM
  #116
No difference but they may have different tailshaft housings.
