Clear Corners
Old Sep 23, 2002 | 06:59 PM
sdf150guy's Avatar
Clear Corners
I want to get some off of e-bay but are they easy to install on a 2002??
Old Sep 23, 2002 | 09:42 PM
drunken_aggie's Avatar
Yes! Just pop your hood, you'll see two tabs near your headlights that you pull straight up. You will need to loosen the torque screw to get the corners out. They should then just slide out. Remove the bulb/socket from the old corner and replace with new corner. Shouldn't take you more than a couple of minutes.
