Antenna Question
My antenna on my SuperCrew hits my garage door and I was curious if anyone knew where I could get a shorter one without any reception interruption. Do they make short billet antennas?
BW,
You can cut your own antenna down, I believe you use a small tubing cutter to score the rod then snap it off. You can then force the end ball off and re-bond it to your shorter antenna. Trndz also sells a billit antenna I beleive you can get it at the online store here.
