Need HOOD info Hail Damage
as a reault of hail damage my SCrew needs a new HOOD......
I am looking for ideas other than the stock hood. I was thinking of some kind of scoop or scoops.
Want some ideas (pics & links would be GREAT)
I want quality ---- and info on painting would be appreciated.
are there any with functional scoops.... or is this a bad thing (either proformance or warranty wise)
truck is an '01 and only 16,000 on it
I know I will get some good advice.... THanks in advance
I'm getting this hood eventually, as soon as the time and money are available
www.carhoods.com It's the "GT-500",,,,,98
If you'd prefer steel over 'glass, here ya go!
Reflexxion hoods
I went with the one that has the scoops. Mine's in for paint work right now, but here it is - in primer!
hdf150painter's got the same hood, see it here
Reflexxion hoods
nchoman - no, the scoops are decorative. There's an indent in the metal & plastic covers fit it, forming the look you see. You could cut the metal from under the scoops, though. There's about a 2" area which could be opened w/o causing a structural problem, and the scoops would cover it nicely.
The cowl IS open, though. Here's a pic of the underside, the two center holes are open, leading to the cowl, which has a screen at the back.
as is my understanding, functional scoops void warranty. try www.americanautodesigns.com. got mine there, best looking in my opinion.
