Need Headlight HELP!!!
Old Feb 9, 2002 | 04:40 AM
Jackal's Avatar
Exclamation Need Headlight HELP!!!
I installed APC Super Whites over a year ago. LOVE THEM!!! They are so bright. 100 / 80.
However, tonight I notice my bright light indicator is partially lit, so I check my headlights, and what do ya know. One side is hardly working. I remove them and install the OEM headights, and get teh same thing. What in the heck is "broke", and what is a safe wattage light to run if I can't go all out with my beasts? Is their some type of upgrade or other? Thanks!!!
-AR
Old Feb 9, 2002 | 11:03 AM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Exclamation
Some people have had trouble with the 100/80 watt bulbs. The headlight harnesses were melting because the high wattage bulbs were overloading the electrical system. This "may" be your problem. Give the harness a look, and see what's up. Once the problem is found, I'd recommend a factory wattage xenon bulb. They give you the brightness, without frying the harness. Good Luck, I have a feeling you're going to need it,,,,98
Old Feb 9, 2002 | 09:55 PM
swampfox25's Avatar
Smile No Problems
I have the 100/80 and I havent had any problems yet. (Knock on wood) But it seems like my low beams are brighter and more intense than the high beams (like the highs are more spread out)
Old Feb 10, 2002 | 02:18 PM
Jackal's Avatar
Exclamation Update...
Had to replace my harnesses, but everything seems fine now. I talked with the shop that I got the 100 / 80's from, and they said that they did away with them, and that Eurolite now offeres a "New Generation" bulb, in stock watage that's HID look-alike, and is brighter than the 100 / 80's. Picked a pair up, and what do ya know...even whiter, and lots brighter!!!
-AR
Old Feb 10, 2002 | 05:46 PM
98SCREAMER's Avatar
Thumbs up
Glad to hear it worked out for you, sorry about the harnesses, though
I've got stock wattage Eurolite xenon bulbs in mine. They ARE nice and bright! With euro diamond headlights, they are even brighter,,,,,98
Old Feb 10, 2002 | 10:48 PM
Jimmy Lee's Avatar
I just had APC super blu's installed in mine...
Hope that dont trash mine!!
JJ
Old Feb 11, 2002 | 09:57 AM
Jackal's Avatar
Question Take em' out...
...and check to see that their 65 / 55. Nice headlights 98.
-AR
Old Feb 11, 2002 | 12:04 PM
98SCREAMER's Avatar
Thumbs up
Thanks Jackal!
I got very lucky on ebay on those headlights, $125 plus shipping!! That's about $75 less than anywhere else I've seen. People still have to pick up their jaws when I tell them that,,,,98
I still miss the old bumper
Old Feb 12, 2002 | 12:40 AM
johnsc's Avatar
Registered User
headlights
Are 65/55 the right ones to buy? How do you know-
do you get the # off of the factory bulbs? Thanks
Old Feb 12, 2002 | 09:00 AM
Jackal's Avatar
Thumbs up Yep...
...anything should be safe up to about 70 I'd think.
-AR
