White Face Gauges
White Face Gauges
Well, my Indiglo gauges quit working for some reason. Not sure why. Anyway I installed some new APC white face gauges. They work off of the factory lighting at night. They are pretty cool. I still liked the indiglo better, but for now this will work.White Face Gauges
You just need to pull the head light switch out, the peice around the steering column, and the peice around the gauges. It should come with instructions when you get you new gauges. It is really a pretty simple install.
I really like those gauges..where did you get them? How do you like the red at night? Does it look OK with the green lighting from the rest of the dash? One last question, are the guages white when the lights are off? Thanks
When installing the "indiglo guages", how do you get the headlight switch out? I pulled the piece off around the steering wheel, then removed all the screws behind that and above the guages, but the switch won't move. What am I missing?
mjhpadi,
I got them from http://www.stylinconcepts.com/. They look ok at night with the other green lights. I'm trying to figure out a way to change my other lighting to red also but I haven't had much luck yet.
spd831sam,
My switch popped out with a flat head screw driver, then I disconnected the 2 plugs and that was it. Hope this helps.
spd831sam,
