Where can I get a front air dam painted and installed?
Old Dec 14, 2001 | 03:46 PM
RMcoolX's Avatar
I will take it to a body shop for the painting, but what about the installation and wiring of the foglights?
Old Dec 14, 2001 | 04:16 PM
crazedf1's Avatar
ask the body shop if they do it. i mean if they fix panels and all the stuff that went wrong when the wreck happened they should be able to do the rest as well
Old Dec 25, 2001 | 11:51 PM
Syeth's Avatar
Just buy a fog light wireing kit man they cost like 19 bucks you just follow the instructions the only things you will need other than that are some butt connectors, wire crimpers, electrical tape, and some zip ties to make everything look good its a simple operation. I wired in my fogs for my lightning fog lights...i did a conversion anyways just by hooking up the relay to the battery hideing it running the wires to the left and right side of the front bumper and then just connecting the wire that brings the signal back from the switch directly to the park lamp wire that comes on when you turn the park lamps on...its the brown wire in the middle on my 97. Anyways good luck its simple.
Syeth
