*Headlight Problem*
Old Dec 10, 2001 | 01:23 AM
ricekicker's Avatar
Registered User
Exclamation *Headlight Problem*
I just purchased the SVT Light set (Headlights, Corners, and Tails) Anyway...after intalling them...I realized that when driving, my low beams seemed EXTREMELY LOW and my HIGH beams seem like they are low beams. I tried taking them out to be sure i didn't align them improperly on the brackets.
Does anyone know if there is an easy way to solve this problem or is this normal?
Thanks for any help or advice.
Old Dec 10, 2001 | 11:08 AM
ricekicker's Avatar
Registered User
Any help is greatly appreciated!
Old Dec 10, 2001 | 03:27 PM
ricekicker's Avatar
Registered User
Heeeeeeeeeeeeellllllp MEEEEEEEEEEE!!!!!!!!! I am going to Crash soon and it's going to be because no one here will help me!!!
Old Dec 10, 2001 | 03:51 PM
mattadams's Avatar
have you tried just re-aiming them? As I recall there are little bolts coming out of the headlight assembly that use about a 4mm socket, you turn them one way and the headlight goes up, turn it the other way it goes down.
Old Dec 10, 2001 | 04:11 PM
my97offroad's Avatar
Hey ricekicker.
Cant help with the light problem, like the user name!!
Old Dec 11, 2001 | 10:08 PM
jstang's Avatar
Use the 4mm socket and check the distance from the mount to the end of the threads. Make sure ts the same as the old ones you took out.
Old Dec 11, 2001 | 10:50 PM
F1504u2nv's Avatar
Yup same thing happend with mine when i put them in, they were aimed way low. So i took them back out and compared the adjustment screws to the ones on my stock lights and found that they were way off. I just started to turn them untill they were the same distance as on my stock lights and put them back in and they were aimed perfectly.
Old Dec 14, 2001 | 04:20 PM
Jimmar's Avatar
Do what I did...
Take the aimer dealies out of the stock lights and put them in your new ones. Therefore they are aimed like they were from the factory There are just a few clips on the deals and they pop right out and in.
Later... don't crash
Jimmar
Old Dec 18, 2001 | 12:03 PM
F250-lariat's Avatar
Lightbulb Replacement Bulbs
I wanted to upgrade the brightness factor in my rear tail lights - found some nice 50w halegon's at JC whitney - how do you know which one fits the fords ??
What a great way to brighten back up lights & stop/turn
Thnx
