CODE 3 Strobe kit
Old Nov 4, 2001 | 09:37 PM
Rich9svn's Avatar
CODE 3 Strobe kit
Has anyone installed a a real stobe kit and not the ones from Trak Auto?
I just purchased a CODE 3 4-way strobe kit.. It does'nt look like it came with any type of swiches (toggle) for the different flash patterens Any suggestions are welcome....
Old Nov 4, 2001 | 09:41 PM
Rich9svn's Avatar
Sorry ON/OFF switch..HI/LO switch and the remote switch for the alternate flashes....are not in box?
Old Nov 4, 2001 | 11:33 PM
SafetyPro's Avatar
Rich,
I assume you mean the Code 3 "hide-away" strobes that are designed for emergency vehicles.
If so, those require a seperate power supply which is what actually regulates the flash pattern. Some provide only one pattern while others have multiple different patterns.
Power supplies run anywhere from $120 to $350, and you can probably get one from wherever you ordered the strobes. If not, Galls (www.galls.com) is a good place to get all that kind of stuff.
Old Nov 6, 2001 | 08:41 PM
fireman467's Avatar
Rich,
To make multiple patterns will take multiple switches. Your instructions should tell you which combination of power wires will make certain strobe patterns. You'll need to out a switch for each one of those wires. I was lazy and just picked one strobe pattern.
Nova makes a strobe power pack that will work with a switch. It will have an on/off switch and a rotary **** to change the pattern. They also have changing random patterns on some models. Anyway, they look really neat. Look at http://www.strobesnmore.com at their switches and maybe you'll get more ideas and will be able to wire up a switch like that.
-Michael
