"Compatable Clear Corners"
Old Sep 12, 2001 | 11:26 PM
beast97's Avatar
Will clear corners, specifically the ones made for trucks built from 2/96-6/97 or whatever it is, fit a 99 F150? Reason being I'm looking at getting a new set of corners for my truck, and I was curious instead of selling them or storing them away, if they would fit on another, newer F150.
Old Sep 13, 2001 | 07:15 PM
ford6mann's Avatar
Nope, they won't fit. The early '97's use a three screw mounting system which is unique to these models only. I know, 'cause I wanted to install '01 L corners on my early '97, so I had to find euro clears that would work. Good luck.
Old Sep 13, 2001 | 11:54 PM
KYFordFreak's Avatar
ford6mann is probably right. The early models used the 3 screw mounting system where the cornor comes out with the headlight. I would consider buying them from you if decided to sell them and they matched what I wanted. I want/need the ones that use the 3 screw mounting system and are the regular clear lens's (not the euro diamond lens type like on the lightning's), and that they were in decent shape. Email me at thomaswright5714@hotmail.com if you would like to discuss this more.
