Wheel help
Old Dec 17, 2014 | 04:44 PM
BigBuckMafia's Avatar
Wheel help
Okay so right now I have 16 inch rims as wanted to go with say like 18 inch rims maybe 17. I am running 315/75r16 ties now. When I search that tire size only 16 inch rims pop up. Now if I went with a 325 size tire I think I find more sizes for rims. Now the rims in looking at inly come in a maximum of 9 in wide. Will I be able to fit that size tire on that rim ? Next off how to the off sets work ? The bigger the negative number the more offset the. 0 no offset and the bigger the positivr number the less offset ? Thanks !
Old Dec 17, 2014 | 05:56 PM
MGDfan's Avatar
Hey.
Ain't nuffin' like sef-hep.
Ever'thang ye needs be in hyur...
http://www.tirerack.com/about/techce...?affiliate=BL1
TireRack FTW
MGD
Old Dec 17, 2014 | 09:06 PM
What's tire rack gonna do to help me ?
Old Dec 18, 2014 | 02:38 PM
AJ@tirerack.com's Avatar
Former Sponsor
Greetings BigBuckMafia,
If you are searching for wheels that will fit a 315/75/16, a 16" diameter wheel should be the only wheel that will show up. Any tire will have a rim width range, and a 315/75/16 will have a rim width range of 8"-10" or 8"-11", depending on the tire. A 325 will obviously accept a wheel slightly wider. 9"-12" tire depending.
Almost every wheel that will carry a tire like this will have a 0 or more negative offset. The closer to 0 or more negative offset you use, the further out from the vehicle the wheel will be.
Here is a link to offset info
Hope this helps and I would be glad to help out further if you have more questions.
-AJ
Old Dec 18, 2014 | 07:46 PM
-AJ
AJ can you email me. hunterbinkiewicz@frontier.com
