Saleen s331 rear bumper problem installing
Old May 10, 2013 | 05:12 PM
garza08's Avatar
I have a complete Saleen s331 rear bumper set up but I can't see how I'm going to install it on my truck I have a 2004 stx an cant seem wats wrong or if something needs to done having difficulty any help would work thanks on how to install
Josh
Old Jun 3, 2013 | 05:30 PM
Jesusfrk's Avatar
Is it a 04 heritage or 2004-08 newer body? If you google saleeninstructions.com there is a pdf you can download the entire S331 body kit instruction manual which shows you exactly how to install it on your F150. Hope this helps you out!
Old Jun 20, 2013 | 11:57 AM
saleen1013's Avatar
If you're still trying at this, here's your answer.
2004-2005 F-150's are somewhat different than the 2006-2008 F-150's. One of the differences is that the front and rear bumpers changed. They mount at different points and are not directly interchangeable without modification.
Old Dec 4, 2013 | 10:18 AM
BBFORD's Avatar
Bumper
Josh
Josh, what did you do.? I'm having the same problem.
Old Dec 9, 2013 | 09:22 AM
Jesusfrk's Avatar
My apologies! Yes the rear bumper mounting points changed in 2006. I've seen guys weld the Saleen bumper reinforcement to the frames to get them to work. You may also try to drill new holes in the Saleen bumper reinforcement so it fits on an 04.
