fiberglass fender flares 4.5" bulge
i was checking these out but wasnt sure how theyd be. i like the beafy offroad look they give but was curious as to how easy they were to mount. thought i would ask yalls opinion.
Do you have the rest of the truck set up to look good like that? Like with some nice suspension etc... Or are you looking to just put aggressive body panels on with a stock truck?
I've seen it done on tv before, fronts not that bad but the bed is pretty involved in tearing the sides off and so on
Unless your running an all out prerunner I dont see why you would want to go full fiber on your truck. Fiber will require a lot of work its never a "bolt on" affair. For the front you will have to get rid of your inner fender well which will require you to move anything thats bolted to it under your hood. And the bed sides require you to either remove the outer skin of your bed and build custom mounts to hang the fiber on, or get rid of the bed all together. It sounds like maybe your wanting something more along the lines of some bushwacker fender flares.
