Reverse Light ???
Old Aug 2, 2010 | 11:59 PM
MmmBuckles's Avatar
Reverse Light ???
I have a wig wag flasher kit laying around that i want to do something with. I was thinking about hooking it up to my reverse lights, only problem is, reverse lights only come on when in reverse.
Does anyone know a simple way to get power to my reverse lights without it being in reverse? Ill be adding a toggle switch to it also.
Old Aug 3, 2010 | 12:03 AM
Hespen537's Avatar
Id tap it into the wireing that runs to the lights. Thats what I Would think is the simplest. Then just toggle the control module. So the module would have a direct power source, instead of the source used to power the reverse lights.
Old Aug 3, 2010 | 12:06 AM
yup easy wire it with a 12v switched wire
Old Aug 3, 2010 | 12:09 AM
thejake1989's Avatar
secondary power supply from the battery with a relay and switch to power them and a diode would also probably be worth while. open to help ya ethan
Old Aug 3, 2010 | 02:53 AM
MmmBuckles's Avatar
what do you mean by diode?
Old Aug 3, 2010 | 08:47 AM
keep the voltage at the light, and not back feeding in to the transmission range sensor
Old Aug 3, 2010 | 09:27 AM
^^^ what he said
