DDM connectors?
Old May 12, 2010 | 07:13 PM
RiverRacerX's Avatar
Question DDM connectors?
Got my DDM Raptor kit today but it does not come with a factory "plug n play" adaper that goes from the ballast to the OEM headlight connector? Just spade ends on the positive/negative wires/
Should I have received, or do they sell an OEM style connector? I don't want to splice anything in case I go back to stock.
What's everyone doing to connect these?
My truck: 2006 F150
Old May 12, 2010 | 09:31 PM
88rxn/a's Avatar
which bulb did you go with? hi/low kit?
those spade connectors are for the hi and low switch. it moves the HID bulb in and out for the high and low beam.
this may help:
http://www.f150forum.com/f4/my-revie...install-52786/
Old May 12, 2010 | 10:41 PM
I got the Raptor lo-beam only 35w kit.
Old May 13, 2010 | 01:10 AM
ELVATO's Avatar
http://autolumination.com/connectors.htm
Scroll down to their bulb connectors (Headlight Pigtail Socket Receptacles), and get 2 H13 males. Get a multimeter and find out which lead is ground, and which is power for low beam. Cut off the spades, and attach them to the male plug you ordered.
Or you could scroll further down and look at their "HID Power Harnesses" and get a 9008 one. All the splicing is down for you Connect 9008 end to OEM and the other end to ballast.
Old May 13, 2010 | 01:31 AM
rednoved's Avatar
My Hi/Lo kit came with the connectors for the factory harness. My foglights however did not. They were just metal pins I had to insert in the factory harness and tape up. I think they are getting cheap or lazy about putting connectors on their wires.
Old May 13, 2010 | 01:37 AM
ELVATO's Avatar
I think it's been like that for the single beams for a while now.
